BeCool/SPAL dual fans cheap - ATI owners upgrade !
***SOLD !! *** THANKS FOR LOOKING
BeCool/SPAL 11" dual puller fans, 2780 CFM. They have been trimmed between 6:00 and 9:00 on the driver side to clear an ATI head unit. These fans are BRAND NEW and have never been installed (just bought them from Summit), I'm going with a single 16" 3000CFM SPAL fan. Comes with everything that came with it in the factory box, basic mounting hardware and instructions - and the piece I trimmed from the driver side fan shroud with a dremel).
I take PayPal. Can ship immediately. I just bought these for $280 plus shipping from Summit.
http://memimage.cardomain.net/member...0_136_full.jpg
http://memimage.cardomain.net/member...0_137_full.jpg
http://memimage.cardomain.net/member...0_138_full.jpg
Thanks,
Rob (Bad30th)
Thanks,
Rob (Bad30th)
Are these a direct replacement? My fans just took a dump and I dont feel like paying a **** load for the dealer to put new ones in.. How much better flow? I can send paypal ASAP if youll let me know.
Also shipping to 32303..
-Nathan
-Nathan
I think the stock fans flow over 3000 cfm, but the ATI supplied 16" fan flows ~1800 ? I wish there was room to use the stock fans with the ATI kit (and keep A/C, etc).
These are not a direct replacement, you would need to fab up a mount.
I've talked to different people about how they mounted theirs, some hung it from the top, and another ran a metal yardstick across the stock bottom supports and bolted the fans up to it.
Shipping to 32303 is about $18 via FedEx ground.
Thanks,
Rob (Bad30th)
Thanks,
Rob (Bad30th)
Thanks,
Rob (Bad30th)
Thanks,
Rob (Bad30th)
Yeah, the ATI supplied fan is not up to par. I cannot run my A/C on hot days (the days I would WANT A/C) otherwise my temp needle starts heading for the red zone.
Why did you decide to not install them and to go with the single SPAL fan?
I found a 16" SPAL Extreme fan that flows ~3000cfm that will mount up to the ATI fan shroud and will work better for my application. The 16" fan will sit in a better location on my setup (right behind my trans cooler, which I installed in the drip tray in front of the A/C condenser).
Cheers,
Rob (Bad30th)
Cheers,
Rob (Bad30th)
