ls1 parts and other
Old Sep 27, 2005 | 04:55 AM
ugoingdown's Avatar
Thumbs up ls1 parts
got to sell all the stuff i have
i have a ls1 bare block that needs the bores to be cleaned out..from what i know it is a 3.905 bore i could be wrong..block is heathy comes with main caps not sure on how meny miles was on the block but it is in good cond. bores are clean...$300
just stock bare block ls1 came out of a 99 camaro 97k bores clean but no cracks
comes with main caps $200
parts from 99 camaro with 97k miles
all o.b.o and in good cond.
asa heads with yellow springs,
casting #853
heads are very clean
$350 o.b.o - SOLD
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
110 LSA 2k miles $150 SOLD
99 camaro all seats - $150 SOLD
30lb injectors for ls1 - $200
crank $200
oil pan $50 SOLD
timing cover $30
stock ls1 heads $100 - SOLD
rockers $40
water pump $50
6-speed steal drive shaft $50 - SOLD
6-speed stock shifter $20
6-speed center console $20
6-speed crossmember $50 - sold
back seats color gray $45
stock 24lb injectors $80
stock slave cyl $25
ac compressor with can $100
ls1 intake with egr hole $100
ls1 intake w/o egr hole $150
slp maf $100
knock sensor's $40
cover for the knock sensor's $30
99 stock black hood $150
all heating piping $35
heater core $20
passenger air bag $100
driver air bag $50
steering wheel $20
blower motor for heat/ac $25
all parts are o.b.o
if need photos please let me know
Old Sep 27, 2005 | 06:54 AM
11SECSS's Avatar
I'd like to get the oil pan....also sent PM
Old Sep 27, 2005 | 07:30 AM
Schitzo's Avatar
PM sent
Old Sep 27, 2005 | 08:58 AM
xssive's Avatar
Ill take the console
Old Sep 27, 2005 | 06:35 PM
quarterback2005's Avatar
I'll take the MAF from ya for $75 shipped. PM me. How much use have you had with it?
Old Sep 29, 2005 | 10:53 AM
FredTT's Avatar
Interested in the hood. What kind of hood is it (V6, Z28 (Two Slits), or SS (scoop))
Old Sep 29, 2005 | 03:56 PM
4bangermustang's Avatar
they are 26lb injectors, LS1's never came with 24's.....
Old Sep 29, 2005 | 09:04 PM
SLP4CamaroSS's Avatar
ls1 intake w/o egr hole $150 sure thats not a ls6 intake
Old Oct 8, 2005 | 01:59 AM
ugoingdown's Avatar
stock z28 hood
Old Oct 8, 2005 | 02:00 AM
ugoingdown's Avatar
it's of a 99 vett..if im right..it's not flat at the bottom
Old Oct 8, 2005 | 02:01 AM
ugoingdown's Avatar
my bad..edited
Old Nov 7, 2005 | 12:43 AM
ugoingdown's Avatar
updated and sent out all pm's
Old Nov 7, 2005 | 12:46 AM
imnotplutonium's Avatar
steel driveshaft? i thought ls1's were allum. if so pm me
Old Nov 7, 2005 | 05:58 AM
ugoingdown's Avatar
yeah sorry i forgot to say it was sold...it was aftermarket not stock
Old Nov 7, 2005 | 09:51 AM
theantirotor's Avatar
pics of ASA cam and stock heads please. pm me.
Old Nov 7, 2005 | 01:30 PM
ONLY 231's Avatar
still have the console? what color is it?
Old Nov 7, 2005 | 07:10 PM
ugoingdown's Avatar
the cam is still in the motor i should be pulling it out some time this week...
ugoingdown's Avatar
it is black
Old Nov 7, 2005 | 07:12 PM
ugoingdown's Avatar
and aslo the heads are sold
Old Nov 7, 2005 | 09:01 PM
well i am very interested in the cam, so please keep me updated as to when you get it out and i will likely take it.
