For Sale: BMR Spring Cups for QA1 shocks on aftermarket springs -almost new
used for about 300 miles before switching over to QA1 Springs. I used these w/ the QA1 shocks and Hypercoil Springs. Worked perfectly. This is a must if you intend to use QA1 shocks w/ most all springs.
..copied from BMR (http://www.bmrfabrication.com/F-bodySuspension.htm)
The QA1 springs made for the Generation F coilovers work fine for the majority of applications, however, if you already have lowering springs or wish to use a custom rate spring, you're out of luck. BMR spring cups can be installed on top of the adjustable shock collar to allow the use of any stock or aftermarket lowering spring. The cups are made out of heavy duty 1/4" laser cut plate and have a machined radiused bevel that matches the coil itself. Sold in pairs, available in red or black powdercoat. $69.95/pair
They are black powdercoated.
I'll sell for $50 shipped
If interested, reply to post or call cell at 678-986-0315
