race parts for sale
i have most of my 500hp na bolt on combo.
all prices are plus shipping, or for pickup purposes i live north of dallas
i can supply pics of any parts needed.
mac mid length headers (wraped) with lanes 3" true duals with x that turn down just before the diff.
$500
exhaust
header
fast intake burst disc, a must for n20, super or turbo charger guys.
these are new never installed. i have a couple sets of these.
$100
random technology adjustable torque arm.
$175
torque arm
mickey tompson 16x25x 11.5 et streets mounted on factory 00' + z-28 wheels. only 2 passes on these, still have some of the tire nubs on them.
$300
wheels
tread
lakewood drive shaft safety loop, new in box
$35
loop
earls stainless brake lines for a 3 channel setup. missing the 5th line that goes from the body to the axle.
$40
i also have an eaton hd posi (the $500 upgraded one when ordering a 12 bolt from strange) with 3:73's for a 12 bolt this has around 1000 miles on it and it has the reluctor ring on it, will work with 3 or 4 channel setups
$250----sold
considering selling my heads, these are a custom set of heads i had made, hand ported, and milled 0.30 to raise the compression. i have flow sheets and dyno sheets, i can also get you the specs of the cam i had in the combo, i may be able to get the cam, my best friend currentyl has dibs on that though. these heads have the best mid flow numbers i have seen, also i relaped the valves when they came off the car.
$1200
eibach pro springs
$75
factory k-member with lower a-arms, (***** joints split)
$25 pick up only
cluster electronics, 14,000mi (and change)
this is the cluster minus the clear cover. ( i dont condone any illegal uses of this, mileage changes needs to be stated for any sale of a vehicle.....yada yada yada )
$250
almost any factory part you want, just ask
k-member, trim, suspension radio, abs, power steering, ac, brakes. ecu and harness
$500
exhaust
header
$100
$175
torque arm
$300
wheels
tread
$35
loop
$40
$250----sold
$1200
eibach pro springs
$75
$25 pick up only
$250
Very interested in the torque arm if it is a crossmember mount, NOT a tranny tailshaft mount.
If there is no damage/excessive wear and is a crossmember mount style (complete with the crossmember and all hardware), put me first in line and let me know your best price shipped to 78729.
Thanks!
Thanks!
Originally Posted by speedracerz
the trq arm is a trans mount.
all head specs i will get out on sun, i am currently out of town, and all pics i can send out at that time also.
If the TA will work with LT headers then I'm interested, what kind of end does it have? spherical/poly bushing? - I also need a washer fluid resevior and a front sway bar - got those items?? Zip me an email with prices/package price shipped to my zip -->> 78641 Austin, Tx email --> townes@coherentlogix.com
Thanks - stevet
Thanks - stevet
$35
pics? low4point3blazer@aol.com
just realized what forum i'm on
its prolly made for an f-body, i need a universal one. so if isn't, nevermind on the pics.
Edit, if THIS is yours, i'm out.
$35
its prolly made for an f-body, i need a universal one. so if isn't, nevermind on the pics.Edit, if THIS is yours, i'm out.
pics on the drive shaft safety loop, chrs1313@aol.com, or pm the product number and i will look up, need it to fit an 02 z28 camaro.
thanks
Chris
thanks
Chris
what compenents are you looking for? calipers, disc, parking shoes, backing plates,
e brake parts (even have the handle) ? let me know
Looking for every rear brake component minus parking brake, even brake lines, and hoses.
