SD tuning using LTFT's with EFILive
posted this over in the EFIlive forums, but can't seem to get any noob help over there....
Ok i know there is a tutorial for SD tuning VE using the autotune feature of EFILive (which absolutely kicks azz) ,
but that requires a WB O2 sensor, which I don't have yet. And when I do get it, I'll then have to find somewhere to get the O2 bung welded onto the exhaust.
So, in the meantime, how about tuning the VE in SD mode, using the LTFT's from the car's narrow band O2 sensors, to get me going in SD mode until I can get the WB ??
I found a write-up using HP tuners on the LS1tech forums, but I figure as powerful as EFILive is, there might be an easier way to set up to do this?
Since there is already a map in the scan tool for LTFT percent, in MAP kPa vs. RPM, can you scan LTFT values in %, then copy / paste those to the VE table, which is also in MAP kPa vs. RPM, to correct the VE to bring the LTFT's down to zero? Does this make any sense?
please help me out
please help me out
what you want to do is use the autotune map and make a calc pids that averages both LTRIM banks (LTRIM1 + LTRIMS2)/2 and plot this on the map by rpm and map. Same procedure different sensors/data
Copy this to the calc_pids.txt file. It is located in My Documents\EFI Live\V7\User Configuration
Code:
# ============================================================================== # File details # ------------ # # This section defines various details about the file format. *FILE #Parameter Value Description #---------- ---------------- --------------------------------------------------- VERSION 7.1.1 File version DECSEP . Decimal separator used in this file # ============================================================================== # Units # ------------------- # See sae_generic.txt for more information on the *UNITS section *UNITS #Code System Abbr Description #-------- ---------- -------- ------------------------------------------------------------- # ============================================================================== # Add slot definitions here # -------------------------------- # See sae_generic.txt for more information on "SLOT" formats # #Units Low High Fmt Expression #------------ ------------- ------------- ---- -------------------------------------------------------------- *CLC-00-015 % -20.0 +20.0 .1 "({SAE.LONGFT1}+{SAE.LONGFT2})/2" # ============================================================================== *PRN - Parameter Reference Numbers # -------------------------------- # See sae_generic.txt for more information on the *PRN section # #Code PRN SLOT Units System Description #------------------------- ---- ------------ ---------------- ---------------- ------------------------------------------ CALC.LTFTTOTAL F015 CLC-00-015 % (Calculated) "LTFT Average Both Banks"
Yes, you can use fuel trims to tune part throttle ve. If you're LTFT's are within +/- 10, you should be using STFT's. The wonderful thing about EFILive is you can make your own MAPs. Just look at the table you wish to change (VE in this case) and then set the MAP up to record the data you want to use to change the table. So, here I would suggest creating a MAP with RPM's in the rows (labels start at 400 and go to 8000 in increments of 400), manifold pressure in the columns (labels start at 15 and go to 105 in increments of 5), and the data is STFT% or LTFT% from one of the banks (as long as you don't have an exhaust leak). Then, go out and log with the MAF sensor disabled/unplugged and filter your data when you get back. Try not to go WOT as it will ignore the O2's if you do. The averages you get are the percent increases or decreases you need to make on each cell.
Edit** Since you have a '98, you need to make the changes to your secondary VE table.
PHP Code:
# File details
*FILE
# Units
*UNITS
*CLC-00-015
"C:\Documents and Settings\timy\My Documents\EFILive\V7\User Configuration\calc_pids.txt(49): Slot not found. . "
Is that because mine is an 02 and there is no LongFT2 ???
Here is another one that you can use as well. This one has two custom pids that allows the same concept as applying the BEN.
Save this file as calc_pids.txt and put it in My Documents\EFI Live\V7\User Configuration. Make sure you have this in there. It appears from your error that it may not be there.
Code:
# ============================================================================== # File details # ------------ # # This section defines various details about the file format. *FILE #Parameter Value Description #---------- ---------------- --------------------------------------------------- VERSION 7.1.1 File version DECSEP . Decimal separator used in this file # ============================================================================== # Units # ------------------- # See sae_generic.txt for more information on the *UNITS section *UNITS #Code System Abbr Description #-------- ---------- -------- ------------------------------------------------------------- None None "" "No units" # ============================================================================== # Add slot definitions here # -------------------------------- # See sae_generic.txt for more information on "SLOT" formats # #Units Low High Fmt Expression #------------ ------------- ------------- ---- -------------------------------------------------------------- *CLC-00-001 %rich -20.00 20.00 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2" *CLC-00-002 factor -20.00 20.00 .2 "({CALC.LONGFTAVG}/100)+1" # ============================================================================== *PRN - Parameter Reference Numbers # -------------------------------- # See sae_generic.txt for more information on the *PRN section # #Code PRN SLOT Units System Description #------------------------- ---- ------------ ---------------- ---------------- ------------------------------------------ CALC.LONGFTAVG F001 CLC-00-001 %rich Fuel "Long Term Fuel Trim Avg Banks 1 & 2" CALC.LONGFT F002 CLC-00-002 factor Fuel "Long Term Fuel Trim - Banks 1 & 2"
This is the end of my new file:
What's wrong with it ?
PHP Code:
__________________
I've got it in the right spot, because first I backed up the existing file (did not move it), then I made the mods to the file and tried to use it, when I got the error. Changed it back and it worked again ??
Thanks for the help, I'm still learning the coding
