FS: TNT F1, Harlan 2-Step, LS6 Manifold, FTRA, Much More
Old Oct 21, 2005 | 05:41 PM
bad2000ss's Avatar
Default FS: Racetronix Pump, O2 Sims, O2 Exten, O2 Sensors, MAF
We've decided to ditch the EFI and go Carburated, so everything fuel injected related has to go. Parts to be shipped will go standard UPS ground to the 48 states only. I am also listing a special Local Pick Up price.
*TNT F1 Nitrous Kit - $500.00 Shipped / $475.00 Local Pick Up SOLD (ARS)
Kit is in great shape. Some very minor wear and tear scuffs on the bottle from pulling the bottle in and out. Switch and relay included. NO wire fittings included. I will also include a Direct flow lid cuto to length for the TNT Power Ring, and an NOS purge Kit (already installed).
*LS6 Intake Manifold w/ EGR Provision - $350.00 Shipped / $340 Local Pick Up SOLD (weaponZ)
Manifold is in great shape. It does come with the EGR Provision for 98-00 cars. It also comes with a Swedgelock cap that I purchased seperate for anyone who plans to or has already deleted their EGR. No LS6 style coolant tubing or plugs.
*Comp Cams Pro Magnum Rocker Arm Kit - $275.00 Shipped / $250.00 Local SOLD (427 LS1)
Very low milage on these. They were installed on a sand rail that saw very limited use. Once set screw for the adjuster nut is missing. I'm sure this could be bought directly from Comp Cams. Other than the one missing set screw this set is complete with studs, adjuster nuts and guide plates in great shape.
*Harlan Two Step - $150.00 Shipped / $145 Local SOLD (Demon_Speeding)
*Racetronix 1999+ F-Body Fuel Pump Upgrade with Wiring Harness - $150 Shipped / $140 Local SOLD (1QUIKWS6)
Very limited use on the fuel pump. Wiring Harness is still new in bag, never installed.
*Fast Toys Ram Air - $125.00 Shipped / $120 Local SOLD (383ss)
*Stock Fuel Rail and Injectors from LS6 - $100.00 Shipped / $90 Local SOLD (427 LS1)
*SLP Line Lock Kit - $80.00 Shipped / $75 Local SOLD (cook_dw)
Includes preformed lines for installation with stock ABS block and original switch. No wire or wire fittings.
*Stock Throttle Body from 2000 LS1 - $75.00 Shipped / $70.00 Local SOLD (427 LS1)
20,000 mile car.
*Oxygen Sensor Simulators (2) - $45.00 Shipped / $40 Local SOLD (Lawnboy)
Sold as a Pair
*Oxygen Sensor Extensions 12" (2) - $25.00 Shipped / $20.00 Local SOLD (Lawnboy)
Sold as a Pair
*NX Activation Switch 15896 (Less Wire Fittings) - $25.00 Shipped / $20.00 Local SOLD (aram)
*K&N LS1 Air Filter - $25.00 Shipped / $20.00 Local SOLD (G-Body)
Paypal, Cash, or Money Order accepted
Thanks for looking. Any questions/comments please post in thread or via PM.
Ross
Old Oct 21, 2005 | 06:19 PM
V6 Bird's Avatar
-=Aftermarket Parts=-
*TNT F1 Nitrous Kit - $550.00 Shipped / $530.00 Local Pick Up
I can throw in a Direct Flow Lid cut to length for the TNT kit with custom bellows (Rubber turbo/blower coupling cut to length) for an additional $40
I can throw in the original LS1 Fuel rail with LS6 injectors installed on manifold for an additional $50
*Fast Toys Ram Air - $150.00 Shipped / $140 Local
*Oxygen Sensor Simulators (2) - $70.00 Shipped / $65 Local
Sold as a Pair
*Direct Flow Lid (Cut for TNT Install) - $50.00 Shipped / $45 Local
Cut to fit TNT Power Ring.
*K&N LS1 Air Filter - $30.00 Shipped / $25.00 Local
*Oxygen Sensor Extensions 12" (2) - $30.00 Shipped / $25.00 Local
Sold as a Pair
*NX Activation Switch 15896 (Less Wire Fittings) - $30.00 Shipped / $25.00 Local
-=Stock Parts=-
*Oxygen Sensors, Front (2) - $90.00 Shipped / $85 Local
Sold As Pair. These only have less than 50 miles on them. Were purchased new and only used for a short trip to the track and back.
20,000 mile car.
*Stock MAF from 2000 LS1 - $65.00 Shipped / $60 Local
20,000 mile car.
Ross
Ill take the 2-step.
Give me an email with your mailing address and i'll have a postal money order in the mail for you Tommorrow.
Mike
Old Oct 23, 2005 | 01:13 PM
bad2000ss's Avatar
Sunday Morning Bump!
Old Oct 23, 2005 | 05:27 PM
V6 Bird's Avatar
I dont have a PM or an email from you with an address to send the money too....Whats up?
mhutto01@yahoo.com is my email.
Old Oct 23, 2005 | 05:54 PM
bad2000ss's Avatar
Hey V6 Bird,
I thought I sent an email though the LS1-Tech system. Apprently it didn't work.
I will send you my address to the email address above and to your message box.
Sorry for the mix up.
Ross
Old Oct 24, 2005 | 11:52 AM
Demon_Speeding's Avatar
Second dibs on the 2-step should it fall through.
Old Oct 24, 2005 | 02:55 PM
bad2000ss's Avatar
I have one more interested ahead of you. If that one falls through, I'll be sure to let you know.
Thanks,
Ross
Old Oct 25, 2005 | 10:19 AM
PM Replied to. Consider it sold.
***EDIT***
Sold to me.
Old Oct 26, 2005 | 05:49 PM
bad2000ss's Avatar
Bump Bump
Old Oct 26, 2005 | 09:16 PM
ATLHwyRacer's Avatar
poor mikey got squeezed!
Old Oct 26, 2005 | 10:16 PM
bad2000ss's Avatar
Old Oct 26, 2005 | 10:35 PM
99 ss's Avatar
do you still have the ls6 intake if you do ill take it does it come with coolet tubs . and how maney milles is on it and can you give me the injectors how big are the injectors . and will i need them for my ls1 or will the stock ones work fine on the ls6 intake. and will you take a money order
Old Oct 26, 2005 | 11:07 PM
bad2000ss's Avatar
Replied in PM.
Old Oct 26, 2005 | 11:52 PM
nvmy2000ss's Avatar
Would like to get in line for the intake if it falls through with 99ss
Old Oct 31, 2005 | 10:04 AM
383ss's Avatar
pm'd you
Old Nov 1, 2005 | 05:01 PM
bad2000ss's Avatar
T T T for the small stuff.
Old Nov 1, 2005 | 05:33 PM
orange88's Avatar
Wiring Harness, Sensors, Coils For Sale?
Old Nov 5, 2005 | 11:02 AM
bad2000ss's Avatar
Prices lowered!
Old Nov 7, 2005 | 02:17 PM
bad2000ss's Avatar
Bump!
Couple new items added.
Old Nov 17, 2005 | 12:55 PM
bad2000ss's Avatar
Prices lowered!
