New GMPP Grand Am Cup Cam and Z06 springs
New in Box GMPP Grand AM Cup Cam GM part # 88958606 $280 shipped
"It features .570" intake and exhaust lift, 251 degree exhaust duration at .050" and 239 degree intake duration at .050". Technical Notes: Center line of intake lobe means M.O.P. or maximum open point, determined across nose of lobe. Lobe flank is not symmetrical - for best torque set intake to TDC@105 degree and for best power set intake to TDC@106.5 degree. Cam timing @ 0.050" tappet lift (timed @106 degrees intake to TDC) Exhaust opens @ 51 degrees and closes @ 20 degrees with duration at 251. Intake opens @ 12 degrees and closes @ 47 degrees with duration at 239. "
Its a brand new cam never used. This is the same cam they have to use in the SCCA World Challenge C6 vettes, and Caddilac CTS V. PTV will have to be checked. 3.73 and lower would be my recomendation. There is somebody on this board that is actualy running this with an A4
Sleep on it if you have to
Ive done some reading up on it, and ive always been curious about it, just not the 450 dollar price tag from GM. The GMPP LS6 heads that go with that cam are milled ~.055 so im not worried about it not fitting in my stock headed car. Yea, ill sleep on it (it seems like the only reason im sleeping on it is so i can say i didnt impulse buy it)
