LS2 coils better than LS1 coils?
Old Nov 18, 2005 | 02:18 PM
FastKat's Avatar
Default LS2 coils better than LS1 coils?
Are the LS2 coils any better or different than the stock LS1 coils?
Old Nov 18, 2005 | 04:08 PM
HSV-GTS-300's Avatar
"The LS2's redesigned coil packs have different wiring-harness connectors and use a revised plug wire with molded right-angle boots."
I read somewhere they produce more per input than the LS1 version.
Old Nov 18, 2005 | 07:44 PM
FastKat's Avatar
so if I have the whol coil pack and bracket setup off of an LS2, I can interchange it with my old coil packs on my LS1??
Old Nov 19, 2005 | 12:52 AM
I got no idea what the effect would be electrically or to the tune by fitting LS2 coils to an LS1.
Physically though they will bolt on to LS1 rocker covers...well all the holes line up. The problems are that the LS2 coil assembly sits over an inch higher up the face of the rocker cover (closer to the injectors), and also the extra thickness of the LS2 assembly at its topmost underneath edge. This thickness is due to the new rectangular hollow section which encloses the main wiring.
The LS2 coil assembly rests upon the vent nipples and hoses at the top of the LS1 rocker cover.....but you could make it fit by using a complete set of longer studs and spacers about 3/4" thick.
Pics below try to show the LS2 assembly and how it ends up closer to the injectors compared to an LS1 assembly. Same piece of wood in each pic.
Old Nov 19, 2005 | 09:28 AM
FastKat's Avatar
Thanks for the info... I never really thought of the tuning implications, but I did have in the back of my head that although they fit, they might not work... I think I'm smart enough to realize that I don't that much about coils, wires, etc!
Has anyone tried running LS2 coils on an LS1 w/LS1 PCM?
