Drag Racing Tech
scatter shields... what are you using
Old Dec 13, 2005 | 05:54 PM
blkchevyz's Avatar
Default scatter shields... what are you using
putting another clutch in the z, figured with the 6k dumps i probably should put a scatter shield on.
what are you guys using?
Old Dec 13, 2005 | 06:17 PM
JL ws-6's Avatar
Race your car!
Only one to use is the mcloud bellhousing... and a good idea.
Old Dec 13, 2005 | 06:21 PM
Fireball's Avatar
but thats only for LS1s...he has an LT1...which I don't think have any options
Old Dec 13, 2005 | 06:23 PM
MADMAN's Avatar
LS1Tech Sponsor
At least put the blanket on it. We dont want to call you "Stumpy"
__________________
www.madmanandcoracing.com
225-343-9029
Old Dec 13, 2005 | 06:43 PM
TOSTO RACING's Avatar
I'm using the blanket Chris. Its better than nothing. I just haven't put my scattershield on yet.
Old Dec 14, 2005 | 04:54 AM
JL ws-6's Avatar
Race your car!
Too bad noone makes a shield like the carbon fiber one I'm putting on with my th400. That thing fits like a glove, and weigh's praticially nothing, and is legal. Someone should get on making one of those.
Old Dec 14, 2005 | 06:32 AM
chpmnsws6's Avatar
who sells the shields for the ls1 t56's? wouldn't be a bad idea to put one on
Old Dec 14, 2005 | 08:43 AM
Fireball's Avatar
anyone who sells mcleod products should be able to get them
Old Dec 14, 2005 | 09:06 AM
chpmnsws6's Avatar
they sell shields and bellhousings
sorry for asking so many questions
Old Dec 14, 2005 | 09:31 AM
Camaroholic's Avatar
The McLeod LS1 transmission bellhousing will bolt to a small block chevy. However, it doesn't have the provisions for mounting the LT1 pull-style clutch hydraulics, and the LT1 transmission input shaft would be too short to use with it. So in theory, you *could* use the McLeod LS1 transmission bellhousing, an LS1 input shaft, and an aftermarket hydraulic throwout bearing (but you'd have to do some research here - and swap to a push style clutch). I don't know if an LS1 hydraulic slave would work in this case or not.
I'm going to be converting my 79 Z28 to a 6-speed, and may use the McLeod bellhousing to bolt the LS1 tranny up to my small block (then again, I may just use my spare LS1 bellhousing and leave one bolt out as the car won't be raced at all). Have yet to do the measurements for the LS1 slave cylinder vs. one-piece rear main SBC clutch setup though.
I used a blanket before I got the McLeod bellhousing from Thunder Racing. Blanket cost me $190 from http://www.exoticmuscle.com - it will fit an LT1 (has a cutout for the fork). http://akmcables.com/engrear.jpg is a pic installed on my bellhousing.
Old Dec 14, 2005 | 12:38 PM
blkchevyz's Avatar
thanks for the info guys. guess i'll go for the blanket, converting mine to work with the shield sounds like a pain in the ***.
is that going to cause any issue with the transmission heating up? i know most manuals dont ever die from overheating, but i do drive this on some trips.
Old Dec 14, 2005 | 12:41 PM
blkchevyz's Avatar
ok ignore the last question. after looking at the picture all it covers is the bell housing so i dont see any issue.
thanks
