Complete 408, BMR stuff, QA1, NX, Double Bottle Bracket
Old Dec 15, 2005 | 11:45 AM
Shane_G's Avatar
Default Turbo 408 Long Block, NX, Dual Bottle Bracket w/ PIX
I was in the process of building a heck of a turbo car but now the tables have turned. Everything is new except the nitrous stuff!
Click here to go to the website with all of the pictures.
All items are located in Murfreesboro, TN which is about 30 minutes from Nashville.
Complete 408 turbo motor built by Texas Speed to hold 1,000 RWHP. Bolted to the crate and ready to ship, here are the specs:
8.9:1 CR
6.0L Cast-Iron Block
Seat LS1 H Beam 6.125" Connecting Rods, .927" Wrist Pins
Eagle LS1 4" Stroker Crankshaft
Clevite LS1 Cam Bearing Set
Clevite H Rod Bearings
Clevite H Main Bearings
Mahle Pro Race 408 Stroker Pistons -32cc
Diamond Racing Pro-Select Piston Rings, 4.030"
Full Block Work & Preparation: Vat Block, Line Bore, New cam bearings, Bore/Hone w/ Torque Plate
Precision Race Components LQ9 Stage 3 Cylinder Heads, 2.08 Intake, 1.60 Exhaust Valves, Fully Assembled w/ PRC Spring Kit
Cometic MLS LS1 Cylinder Head Gaskets, 4.030" Bore .040" Thickness
Comp Cams OE-Replacement Hydraulic Roller Lifters
ARP LS1/LS6 Cylinder Head Studs, 12 Point
Rollmaster Double-Roller Non-Head-Treated LS1/LS6 Timing Set, Standard Bearing
Texas Speed Turbo 244/240 XER Camshaft
Texas Speed & Performance Modified LS6 Oil Pump
This is a deal at $6,300 plus shipping.
All prices are plus shipping.
NX Remote Bottle Opener $150
NX Bottle Heater $100
Dual Bottle Brackets $225
Old Dec 15, 2005 | 12:01 PM
Matt D's Avatar
Retired Street Racer
Are the LCA brackets bolt on?
And, what type of shocks for the front and what spring rate?
Old Dec 15, 2005 | 12:06 PM
Shane_G's Avatar
They are the weld on brackets.
I'm not sure what the spring rate is on the HAL's. The invoice says, "Hal/QA1 Shocks & Spring Package: Front 12-Way adjustable Shocks, Front Drag Springs, Rear 12-Way Adjustable Shocks."
I'll send Jason at Texas Speed a PM and see what he says. I told him what I wanted to do with the car and he decided on the parts I needed.
Old Dec 15, 2005 | 12:35 PM
Detroitmuscle's Avatar
PM sent of SFCs
Old Dec 15, 2005 | 01:33 PM
Shane_G's Avatar
All PM's replied.
Old Dec 15, 2005 | 01:58 PM
John Junkins's Avatar
Sent you a PM.
Thanks, John Junkins
Old Dec 15, 2005 | 02:06 PM
Shane_G's Avatar
Originally Posted by John Junkins
Sent you a PM.
Deal done.
Old Dec 15, 2005 | 02:19 PM
GOGO's Avatar
You have a PM.
Old Dec 15, 2005 | 02:39 PM
Shane_G's Avatar
Originally Posted by GOGO
You have a PM.
Replied.
Old Dec 15, 2005 | 06:28 PM
slow01z28's Avatar
Sent you pm
Old Dec 15, 2005 | 06:34 PM
John02SS's Avatar
Please find out if they Hal's are F's or R's and the rate on the springs. I'm very interested in them. PM me when you find out.
John
Old Dec 15, 2005 | 08:15 PM
Shane_G's Avatar
All PM's are replied too. The part number on the box is 15FB275.
Old Dec 15, 2005 | 09:10 PM
Shane_G's Avatar
Prices have dropped on the nitrous stuff.
Old Dec 15, 2005 | 11:01 PM
Mongoose98's Avatar
Who built the motor?
Old Dec 15, 2005 | 11:39 PM
JRracing's Avatar
Will you take 155 for the timing tuner? Your price is only a little off of the new price.
Do you have the paper work with it?
Is all the wiring with it, it looks like it. PM me please. Thanks, Jeremy.
Old Dec 16, 2005 | 07:36 AM
Shane_G's Avatar
Texas Speed.
Old Dec 16, 2005 | 07:38 AM
Shane_G's Avatar
I sent you a PM.
Old Dec 16, 2005 | 12:25 PM
Shane_G's Avatar
Price dropped on the engine.
Old Dec 16, 2005 | 03:56 PM
SuperSporttruck's Avatar
whats the new price on the motor
Old Dec 16, 2005 | 04:12 PM
Shane_G's Avatar
