Autometer Boost/Vac Gauge, Fuel Pressure Gauge, Triple Gauge Pillar, ATI MMS Pulley
Old Dec 15, 2005 | 08:01 PM
Ferocity02's Avatar
Default Autometer Boost/Vac Gauge, Fuel Pressure Gauge, Triple Gauge Pillar, ATI MMS Pulley
Autometer Triple Gauge Pillar: Designed to cover your existing A-pillar and holds three 2-1/16" gauges. Also comes with an OEM A-pillar that has the holes already drilled in it so you don't have to cut into yours. All that it needs are a few short sheetmetal screws to mount the gauge pillar onto the A-pillar. Fits 98-02 Camaros/Firebirds with T-Tops. Not sure if it fits LT1 cars... SOLD
Autometer Phantom Electric Boost/Vac Gauge: 2-1/16" in size, full sweep. Looks brand new, no scratches on the face. Comes with everything that it came with from Autometer including the sender, wiring harness, bulb covers, mounting bracket, grommet, vaccum line and fittings. Extras include fittings that I bought to tap into the brake booster line for accurate readings. Also included some sheetmetal screws that I used to mount it and some thicker rubber vaccum line. This gauge has a peak boost recall so you don't have to keep your eye on the gauge to see you max boost. It also has a warning light to let you know when you reach your set boost limit. Goes from 30 In.Hg vaccum to 15psi of boost. It is accurate, fast, and works flawlessly. This gauge also allows for data logging... $145 Shipped
Autometer Phantom Electric Fuel Pressure Gauge: 2-1/16" in size, full sweep, 0-100psi. Looks brand new, no scratches on the face. Comes with everything that it came with from Autometer including the sender, wiring harness, bulb covers, mounting bracket, and grommet. Extras include very hard to find fittings that I got to convert -4AN to 1/8"NPT. The fittings allow you to mount the sender right onto the end of your fuel rail. It also has a schrader valve so you can bleed the fuel system pressure without removing the sender. This gauge is also very accurate. No problems whatsoever. This gauge also allows for data logging... SOLD
MMS 8" Crank Pulley: For use with ATI Procharger 6-Rib systems. Allows you to run more boost without using a smaller blower pulley. This helps to reduce the chance of belt slip. This pulley is capable of up to 15psi slip free. The small pins on the back of the pulley sheared off but where replaced with some larger heavy duty roll pins. There was a little damage from this accident but it was repaired easily. The pulley turns straight and true... SOLD
Offers accepted. PM me for more info, Thanks for looking!
Old Dec 15, 2005 | 09:22 PM
quicksilverado's Avatar
Would you take 150.00 shipped for the fuel pressure gauge?
Old Dec 15, 2005 | 09:46 PM
Ferocity02's Avatar
PM Sent!
Old Dec 16, 2005 | 07:54 PM
tmister's Avatar
Default Pillar and 2 Guages
My offer would be 275 for the gauge pillar and the 2 guages(fuel and boost).
tmister@***.net
Old Dec 16, 2005 | 08:01 PM
IVRedZ28LS1's Avatar
Interested in Triple guage pillar. By itself, no guages.let talk $
Old Dec 16, 2005 | 11:35 PM
Ferocity02's Avatar
Prices lowered!
PM's sent!
Old Dec 17, 2005 | 12:08 AM
BlutVonSchwachen's Avatar
Interested in the pillar and fuel pressure. Pm me with a price for both please. Tks.
Old Dec 17, 2005 | 12:55 AM
Ferocity02's Avatar
PM sent!
Old Dec 17, 2005 | 10:30 PM
Ferocity02's Avatar
Will trade for an Autometer Phantom Oil temp guage.
TTT
Old Dec 18, 2005 | 08:54 AM
scalemaster's Avatar
pm sent
Old Dec 19, 2005 | 07:34 PM
Ferocity02's Avatar
Boost gauge and pulley still for sale. Reasonable offers accepted.
Old Dec 21, 2005 | 07:36 PM
Ferocity02's Avatar
Prices lowered A LOT!
Old Dec 23, 2005 | 12:00 PM
HILL_SS's Avatar
Im interested in the MMS Pulley if you still have it...Shoot me a PM with your Lowered Price
Old Dec 23, 2005 | 08:17 PM
Ferocity02's Avatar
Boost gauge is still left! Its on eBay now.
http://cgi.ebay.com/ebaymotors/ws/eB...ALCA%3AUS%3A31
