NEW Crane Cams Dual Valve Spring Kit with Titanium Retainers
Complete brand new Crane Cams Dual Valve Spring Kit with Titanium Retainers, good to .650 lift.
$225 shipped. Paypal. SOLD SOLD SOLD
• Made from premium quality chrome-silicone steel
• Precision-wound and heat-set for durability
• Spintron-proven and dyno-tested
• Increases horsepower and torque yield for any LS1 cam profile
• Quiet-operating dual spring design controls harmonics without triggering stock "knock sensor"
• Matching titanium alloy spring retainers
• No-machining required to install
• This is the LS1 spring that works and doesn't break!
Outer Diameter Outer Spring 1.275
Outer Diameter Inner Spring .937
Inner Diameter Inner Spring .667
Seat Pressure @ Installed Height 112 lbs @ 1.800
Open Pressure and Height 352 @ 1.150
Coil Bind 1.045
Maximum Net Lift w/.060" Clearance .650
Average Spring Rate (lbs./in.) 352
Coil Bind 1.045
