map wire broke at connector now what?
There is no wire to solder it back to so i need a new pin or connector. D oes GM make a repair kit for these?
Dave
Dave
Generally, you can find replacement pins for just about any style of connector that GM makes. You just have to have a good parts store to get em. Advance, Pep Boys, and other chains most likely aren't gonna have them. If you can't find them you can order a new connector from GM. That would cost you about $30. I might have a pigtail laying around in a box around here. Let me know if I can help or not.
Well, I have one on my 2000 s10 4.3 V6 harness which is in about 100 pieces. I took the MAF connector off it and it does fit into the LS1 MAP sensor, but it isn't the same color code. I don't know if that matters to you or not, you would just have to ensure you follow the route and not the color code. If you don't care then consider the connector yours. IF you want it Just get me your addy and how soon you want it by and I will send it off with about 4 inches of wire attached. I would just expect a return payment of what you would consider "a fair price" for the connector. Sound like a deal?
color code doesnt matter, ill just pull that one pin out and solder it into the exsisting one. Hows 10 shipped sound? Drop it off usps it shouldnt cost more then a 3.85
Dave
Dave
