Parts for SALE (Pullies/Mcloed Clutch/etc...)
*SuperCharger parts:
6 RIB:
New 3.6 SC pulley 50$
New ATI 6 rib tension pulley $20
New ATI 6 rib Crank pulley $90
New 6 rib belt to fit the listed pullies. $15
Boost levels will be between 7-9psi depending on the setup.
8 RIB: Need ATI SuperDamper with it
Used 4.25" SC pulley $60
Used 8.5" Crank pulley SOLD
Used belt to fit the 4.25 and 8.5 crank. Free with the pullies
Boost levels will be between 10-12psi depending on the setup.
*Brake parts:
BrakeBooster $180 shipped
This unit is almost new. A shop made a mistake in diagnosing the problem with the brake system and changed the Brake Booster and it turned out to be another thing. So I'm stuck with an almost new Brake Booster. This thing cost me $340 new from the dealership.
*Mcloed Kevlar/Organic with steel flywheel Clutch kit: SOLD
The disc needs to be rebuild as well as resurfacing the flywheel. The pressure plate could be reused but Mcleod said they would warranty the clutch if a new pressure plate was included in the rebuild.
The prices for a rebuild are as follow: (source: Mcleod Industries)
$80 for a new disc.
$180 for a new pressure plate.
and $25 for resurfacing the flywheel.
So at the end the buyer would be getting a new Mcleod Kevlar/ Organic clutch with new warranty for $535.
6 RIB:
*Brake parts:
$80 for a new disc.
