SD tuning a 1998 car...
Old 01-26-2006, 12:25 AM
RW99's Avatar
Question SD tuning a 1998 car...
OK, so let's say I want/need to ditch the MAF on my 1998 turbo TA.
What is the current status of speed density tuning for this year PCM? Last time I tried to find info on the subject, it sounded like the '98 cars weren't supported.
The car will be set up to produce something on the order of 600 rwhp/rwtq using a T67, expecting to use something on the order of 10 lb boost. So we're not talking crazy numbers here, but still something past what the MAF can handle.
Thanks in advance for any info,
Rich
Old 01-26-2006, 07:19 AM
Doc
Doc's Avatar
What kind of performance do you get out of it now with the maf? From what I understand- and it is limited, you should be fine up to 8 but you are already at 10 right? I would think that you would need 2bar support and in that case I don't think anybody currently supports the 98 OS for that. PM eallanboggs he has a 98 turbo setup with efilive he might be able to help.
Old 01-26-2006, 09:44 AM
ESR
LS1TECH Sponsor
ESR's Avatar
Default tunes
Its 99 on up for SD tuning.........even then some 99's do not support III bar apps.........only II bar this is with HP tuners not sure on EFI
Rich
Old 01-26-2006, 09:57 AM
RW99's Avatar
The car is a brand new turbo install (with AFR 225s), and is outflowing the MAF earlier than anticipated... getting some boost spike early on and having a difficult time tuning via "normal" means. Switching from a simple Boost-T controller to an Eboost2 to try to get a handle on it. I see what you're saying; I forgot about the 2bar thing. Thanks for the heads up on eallanboggs.
Rich
Old 01-26-2006, 10:00 AM
Blacker's Avatar
Another guy to get in touch with is MightyMouse. He has +900rwhp single turbo 98 Formula.
Old 01-26-2006, 10:05 AM
ESR
LS1TECH Sponsor
ESR's Avatar
Default .....
Im pretty sure if mightymouse is running BS III or something else and if hes using HPtuners its at least a 99+ pcm. You can reflash the 99 pcm with a 2000 tune if you have both licenses.......then add the III bar to it.
Old 01-26-2006, 10:15 AM
bmfcamaro's Avatar
may want to call rick@synergy -------------------> he has made these work. wiring in a 2 bar and fudging the tables.
Old 01-26-2006, 10:23 AM
ESR
LS1TECH Sponsor
ESR's Avatar
Default ...............
If this is the case Id like to see a write up on it...........just cant see how the ve table would would extend far enough it would still only read so far. Im more curious than anything now.
Old 01-26-2006, 02:05 PM
slow's Avatar
If you install a 2 bar map sensor, and force the car into SD, the VE will only read 1/2 way at 0 vacuum. So It should work fine, just have to play with the numbers.
Ryan
Old 01-26-2006, 05:35 PM
bmfcamaro's Avatar
Ryan
correct. you should do a search or call him before you get all negeative. it was posted on how to do it, and he is more than willing to help people out. just call
Old 01-26-2006, 05:40 PM
frcefed98's Avatar
I'm a 98 running a 2bar SD tune 14psi no problem and the car runs great.
Rick@synergy is the man to call. He is extremely nice and very helpful. http://www.synergymotorsports.net/
J
Old 01-26-2006, 06:01 PM
slow's Avatar
I don't see how this is being negative by my responce.
Granted 95% of my other posts are anti SD tuning, but I thought my responce was informative, and gave a general direction of how to pursue trying to SD a 98 car.
Ryan
Old 01-26-2006, 07:14 PM
bmfcamaro's Avatar
sorry meant ESR not you. the correct was for your statement. the rest was for ESR
Old 02-02-2006, 07:40 PM
BADFNZ's Avatar
So do you need a 2 bar setup to do SD on any '98, or just for those going FI?
Old 02-02-2006, 09:03 PM
slow's Avatar
2 bar is only applicable with boost.
Ryan
Old 02-02-2006, 11:42 PM
BADFNZ's Avatar
So there is no issue doing SD on a 98?
Old 02-03-2006, 12:01 AM
bmfcamaro's Avatar
you can do an sd tune on a 98, but when you have boost is when you get creative. my car has been running an sd tune for a year or so. works great.
Old 02-03-2006, 01:56 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
J
every one talks about it and i can't find it, can some one link it
Old 02-03-2006, 12:00 PM
bmfcamaro's Avatar
do a search for rick@synergy all posts. there will be one that states sd 2 bar for 98's. cant do all the work 4 u.
Old 02-03-2006, 04:05 PM
frcefed98's Avatar
Just email or PM rick@synergy. He is extremely helpful and genuinely helps, just gotta ask.
J
