Pedals, Gears, o2 Sims, LT4 Knock Module, Hypertech, Welder
6 speed aluminum pedal covers
good condition, used. $32 shipped overnight
Stock 3.42 gears for 10bolt : SOLD!!!!
AC Delco LT4 Knock Sensor: SOLD!!!!
2 o2 Simulators with lights:
Used but in great condition. Paid $90..... $67 shipped overnight
Hypertech Power Programmer III for LT1s:
Power Programmer III 97 Camaro/Firebird LT1/V8 (1008 req)
More performance from your fuel-injected vehicle.
Looking for a fast and easy way to add horsepower? These Power Programmer III units are as easy to use as pushing a button, and require no tools. They plug into your vehicle's sub-dash diagnostic port, and reprogram your computer with true performance curves for fuel and spark. Hypertech's programs will give you more performance throughout the entire rpm range, not just in the top end, like other brands.
Used once, still in box w/ instructions, great condition. PN-375752 Paid $399.99..... $125 shipped overnight
Craftsman Gasless Wire Feed Welder:
Wire speed control with Tweco-type torch
Operates on standard 110 volt current
20% duty cycle at 80 amps
Automatic thermal safety switch prevents the possibility of overloads
Gasless convenience - uses flux-cored steel welding wire
Welds thin 18 ga. sheet metal up to thick 3/16 in. steel for versatility/wide range of uses
Dual position heat adjustment for selecting the perfect heat for the job
Adjustable wire tension for accurate, reliable feeding
5 -.023 contact tips, 5 -.030 contact tips, 5 .040 contact tips, starter spool of wire
CSA approved
Used twice in perfect condition. PN-20568 Paid $229.... $175 ...local only, will not ship
I am selling these for a friend, I will be the contact point, look at my seller rating.
CSA approved
Originally Posted by LETZ RUN
[b]
Ill take that hypertech power programmer if it has been released.....
Dibs!
Please send me the payment info on this so I can send you the payment. Thank you , Robb.
Email me please @ robb4964@yahoo.com so I can send you a payment.
Dibs!
