Picture of Racetronix dual pump harness..super quality.
Coal Mining Director
The picture doesn't do this harness justice. Dual 40 amp relays, dual 20 amp fuses, dual option trigger connectors, 10 gage wire to each pump, Direct battery connectors....Racetronix is ate up in quality products...all plug and play.
The harness cost varies as to the options. Budget around $200...depends if you want a hobbs switch,etc.
I'm doing a custom tank with dual intank Bosch pumps...pictures to follow.
Here's a couple of sneak pics. I'm going to do a layout later on. The two Bosch 044's are mounted at the back of the tank. If you look in the cutaway you'll see the stainless lines going to each pump. The wiring and -8an connections was brought to the outside of the tank as in the second photo.
I've also got the racetronix twin setup with the hobbs switch... quality is second to none and it's super easy to install... Just make sure you tell them if you have a rear mounted battery or not... they will fab up a custom harness if you do... Lonnie's performance rocks!!!!
