408 Balanced Rotating Assembly - Iron Block - TSP Giant Cam - Much More!
Old Feb 22, 2006 | 11:11 PM
Armageddon's Avatar
...with cheese.
Default 408 Balanced Rotating Assembly - Iron Block - TSP Giant Cam - Much More!
I'm parting out my 408. Everything is perfect, low mileage.
6.0L Iron Block 4.03 - Bores are ringed with Stainless Wire
Bores are perfect, no cleanup required
Local Preferred. Dothan, AL - Orlando, FL SOLD
Balanced 408 Rotating Assembly
4.03" Diamond Double Stack Crown Lowered Stack Custom Pistons
Eagle 6.125" Rods w/ ARP Premium Rod Bolts
Eagle 4" Crank
This rotating assembly with these pistons would produce the following compression with different heads.
11.5:1 LS1 Heads
10.9:1 6.0 Heads
12.0:1 5.3 Heads
All assuming stock chambers and MLS Gaskets.
Assembly has been professionally balanced and is ready to go! Pistons have valve reliefs also.
SOLD
Texas Giant Cam 248/254, .611"/.613" 113*
Has maybe 500 Miles on it. Excellent Condition
$325
Trick Flow .5" Valve Cover Spacers. Nice little setup, comes with Bolts and gaskets.
http://store.summitracing.com/defaul...2&autoview=sku
Sell for $215 new on Summit.
$165 Shipped.
Yella Terra Shaft Mounted 1.7 Roller Rockers
Excellent Shape - Little to be said here
SOLD
Old Feb 22, 2006 | 11:19 PM
JZ'sTA's Avatar
So your selling all these parts taken apart.
May I ask why you took the motor apart?
Basicially your asking 2000 for a complete non assembled shortblock. (Plus rings, berrings etc)
I have to believe you could have made more selling this together.
Old Feb 22, 2006 | 11:26 PM
Armageddon's Avatar
...with cheese.
The motor is in the car, running right now. It's got about 500 miles on it. I could sell the motor complete if somebody wanted it like that. Doesn't really matter to me. It's easier to part out stuff I've found.
Old Feb 23, 2006 | 12:22 AM
revlimiter's Avatar
$550 +shipping Local Preferred. Dothan, AL - Orlando, FL
Eagle 4" Crank
11.5:1 LS1 Heads
10.9:1 6.0 Heads
12.0:1 5.3 Heads
$1500 Shipped
$325
$165 Shipped.
$350 Shipped
Does the block come with main caps? And if so, stock or...?
thanks
Old Feb 23, 2006 | 01:49 AM
chrismcdaniel's Avatar
pm sent'
Old Feb 23, 2006 | 04:08 AM
Armageddon's Avatar
...with cheese.
thanks
Stock caps included.
Old Feb 26, 2006 | 02:32 PM
383ss's Avatar
would you seperate the pistons? are they flat top?
Armageddon's Avatar
...with cheese.
The short block is sold.
Old Mar 18, 2006 | 11:24 AM
JZ'sTA's Avatar
Damn I asked a question and never noticed your reply.
I would have bought it if I new it was together.
Owell.
TTT for you
Old Mar 18, 2006 | 06:27 PM
styles2769's Avatar
Thats too bad, he was going to coming down here anyways......
