FOR SALE: DiabloSport Predator Tuner
Old Feb 25, 2006 | 02:21 PM
Grave's Avatar
Default FOR SALE: DiabloSport Predator Tuner
Sold my Camaro today, so I no longer need my Predator tuner.
The factory tune was re-installed into my car, and the performance tune was restored to the tuner.
This Predator will work for the 1999+ LS1's. Included is the original box, and instruction manual.
In order for the tuner to work on your vehicle, read this FAQ from DiabloSport. According to their FAQ, you'll need to send them $99 for them to "unlock" the Predator for it to work on your vehicle.
I was selling this tuner for $300, but since I read DiabloSport's FAQ, I'm knocking $100 off the price.
I'll now take $200 + shipping for the Predator.
Old Feb 25, 2006 | 02:27 PM
Black Soul SS's Avatar
what can u do with this tuner???
Old Feb 25, 2006 | 02:50 PM
Grave's Avatar
They're a sponsor on this site, check it out. --------->
Or just go here...
http://www.diablosport.com/main.php
From the website:
Predator tunes re-map the:
Fuel Curves
Timing Curves
Torque Management
Extend Speed Limiters
Extend Rev Limiters
Disable CAGS (Skip Shift)
Part and Full Throttle Shift Points
Shift Timing
Shift Presure
The Predator allows the end user to adjust the following parameters:
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Injector Adjustment
Adjust for different injector size
Adjust for long term fuel trims
Catalytic Overtemp protection Adjustement
Disable P0430 and P0430 codes
Adjust COT enable temperature
EGR disable
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
Multiple Misfire P0300 adjustement
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
AIR code disable
Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
Old Feb 25, 2006 | 03:21 PM
what's the least u want for it?
Old Feb 25, 2006 | 03:23 PM
Grave's Avatar
I'll take $300 + shipping.
Old Feb 27, 2006 | 08:53 AM
Grave's Avatar
T T T
Old Feb 27, 2006 | 09:31 AM
618HAWK's Avatar
Has it been unlocked from your vehicle?
Old Feb 27, 2006 | 10:03 AM
Grave's Avatar
Before I sold my car I restored the factory tune.
From what I understand, in order to unlock the tuner, you need to restore the factory tune... then you have to mail send DiabloSport $99 to "unlock" it.
You can read about it here.
So it's a two step process:
Step 1: Restore factory tune (I did this)
Step 2: Send DiabloSport $99 to "unlock" the tuner (buyer needs to do)
I just found this out myself. So, because of this... I'll knock $100 off the price of the tuner, and will now sell it for $200 + shipping.
Old Feb 28, 2006 | 08:30 AM
Grave's Avatar
T T T
Old Feb 28, 2006 | 05:50 PM
Grave's Avatar
T T T
Old Mar 1, 2006 | 08:02 AM
Grave's Avatar
T T T
Old Mar 1, 2006 | 01:01 PM
Grave's Avatar
Still available!
Old Mar 1, 2006 | 04:04 PM
ded71's Avatar
What year car is the tuner for? I'm interested.
Old Mar 1, 2006 | 04:48 PM
Grave's Avatar
1999+ LS1's
Old Mar 2, 2006 | 09:17 AM
Grave's Avatar
Still available!
Old Mar 3, 2006 | 08:56 AM
Grave's Avatar
T T T
Old Mar 3, 2006 | 05:04 PM
Grave's Avatar
SOLD!!
