Misc parts, patriot springs, LT1 intake, heads, etc.
I have a couple things im tired of tripping over so Id like to see if anyone is interested in these.
A pair of cast iron LT1 heads, Bare! I may have the valves but not sure if they are all there. Bought an LT1 last thurs that had these on it. The valves, PR's were in a bucket so Im not sure if they are all there. $25 plus shipping
Air pump/egr valve in perfect condition. These are off a 99 Z28, There are 2 air pumps how I ended up with to Ill never know but consider is an extra if you buy it. Worked fine when removed, also have the hose. $20 plus shipping
Stock 26.6lb injectors, removed a couple weeks ago work perfect. $10 plus shipping *SOLD*
Stock Timing chain from a 2001 Trans am. 32,000 mi. Seems to be in good condtion, I havent used it, I just replaced it while doing a cam swap. $5 plus shipping
Stock oil pump from my 99 Z28. 62,000mi Works perfect. Removed once I installed the 408, for a ported LS6. $15 plus shipping
Patriot Dual valve springs. Roughly 1300-1500mi on these. They do have all the locks, retainers, seats, & Ill even inclued a brand new set NIB of valve seals. $160 plus shipping *SOLD*
Stock cam sprocket, 62,000mi. removed from my car for an adjustable one.
$5 plus shipping.
Stock rockers, also removed from my car with 62,000mi. they worked fine when removed them. One look s brand new but its not I sprayed brake cleaner on it to see if it would come clean, then I didnt feel like cleaning the rest. All bolts are also included. $40 plus shipping
Stock LT1 intake with fuel rails, injectors & TB from a 97 camaro, Once again I bought an LT1 with a ton of parts so I havent personally used this before. I can seperate if someone needed, a TB or injectors or just the intake or etc. $75 plus shipping for all of it. *SOLD*
Stock LT1 water pump from a 97 camaro. Came with project. looks in good shape. Missing the temp sensor. $40 plus shipping*SOLD*
Dual valve springs. Not sure what these go to. They too came with the LT1 project. All the springs are there one is missing a retainer. Not sure of the brand either. If I had to guess compared to the LT1 springs & the LS1 springs Id say they go to a SBC. They look brand new. $20 plus shipping.
Thats if for now, Once I clean more shleves/boxes Ill have more to post. I have access to UPS at work so the shipping prices will be cheaper then normal. If you have any question just shoot me a PM or post up.
Thanks!
$5 plus shipping.
Thanks!
