fuel rail install
Old Mar 1, 2006 | 09:15 PM
j99fbody's Avatar
Default fuel rail install
I have a set of fast fuel rails im putting on my 99 z28. Not sure what i need to do, been reading alot of threads, but I am confused. Do i need a return line because i didnt think my stock ones had one and do i need a regulator and where would i place it if i do? I was going to use my factory fuel feed lines.
Old Mar 2, 2006 | 01:20 AM
Nasty N8's Avatar
I have a kit instock with everything needed to addapt to the factory feed line. Just some fittings and hose. No need for a reg. it is in the tank. Give me a call tomorrow I will set you up.
Nate
Old Mar 2, 2006 | 05:35 AM
Flash99's Avatar
Default Call Nate
Yeah call up Nate, he hooked me up via overnight for my fittings that I desperatly needed for my rails, not sure how good you can see it in the picture below, but you can see the fuel line going to the top of the rail.
Flash
