LS1 performance parts
Old Mar 3, 2006 | 02:40 PM
styles2769's Avatar
Default LS1 performance parts
*LS6 stage 2 ported heads - $900.00
*SLP LT coated headers. $500.00
*Patriot performance 1.7 Rockers. - $300.00
*Weld Prostars, 15x3.5 fronts, 15x8 rears, M/T ET street radials (275/50R/15), widetrack front runners, 5/16 spacer, center caps, all lugs and washers. - $950.00
*Built T-56 tranny w/ spec stage 3 clutch kit, Viper output shaft, Pro 5.0 shifter - https://ls1tech.com/forums/lsx-parts-sale/463010-built-6-speed-pro-5-0-shift-f-s.html
*center bolt valve covers, perfect for 97-98 head/cam swap, coil brackets, brand new from GM. - $175.00
*Qa1 12-way ADJ coil-overs (front and rear), 275# front springs. - $600.00
*John Lingenfelter intake manifold - $330.00 $549.99 brand new
Old Mar 3, 2006 | 02:46 PM
Azar's Avatar
LS1TECH Sponsor
Where did you buy the ported heads from? Thanks..
Old Mar 3, 2006 | 02:48 PM
Midnite_LS1's Avatar
Sent PM on the prostars...
Old Mar 3, 2006 | 03:13 PM
MonsterZ28's Avatar
man i want that hood, i dont have that much though, are you willing to trade for a z hood and some cash
Old Mar 3, 2006 | 05:22 PM
exstanger's Avatar
How many miles on the prostars and tires. Also same ?'s on qa1's. Are they R'S or F'S
Old Mar 3, 2006 | 05:42 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
PM sent regarding 10-bolt rear
Old Mar 3, 2006 | 05:46 PM
styles2769's Avatar
prostars have about 200 miles on them
Qa1 has about 2,000 on them
everything is in great condition
Old Mar 3, 2006 | 05:47 PM
styles2769's Avatar
I have a Z hood already, sorry
Old Mar 3, 2006 | 05:48 PM
exstanger's Avatar
Sent you aPM with more ???'s.
Old Mar 3, 2006 | 05:56 PM
styles2769's Avatar
sent PM's to exstanger and ZRO
Old Mar 4, 2006 | 10:50 AM
JZ'sTA's Avatar
Nice stuff for sale.
Good luck
Old Mar 4, 2006 | 02:39 PM
JZ'sTA's Avatar
The heads are acturally mine I was just having Styles sell them for me.
A former employee from MTI hand ported them. He now lives here in Ft. Myers and ports LS1 heads full time.
We are changing out to a set of ET Performance heads and upping the compression. This is the reason these are for sale.
The heads are 600 dollars just for the castings, so your geting a fully ported set of heads for 300 dollars.
They will come complete with valve springs and stock valves.
I have a comp 915 spring on them now.
For a extra 75 dollars I will include new AFR dual springs.
Old Mar 4, 2006 | 08:17 PM
styles2769's Avatar
Bump....
Old Mar 5, 2006 | 11:05 AM
styles2769's Avatar
Ttt.........
Old Mar 5, 2006 | 11:15 AM
redfbird99's Avatar
is this a complete rear end? How many miles are on it? im interested.
Old Mar 5, 2006 | 11:21 AM
styles2769's Avatar
the stock rear is no longer avalible.....THANKS
Old Mar 5, 2006 | 12:19 PM
JZ'sTA's Avatar
Harland Sharp's are gone as well.
T T T for you.
Old Mar 6, 2006 | 03:45 PM
JZ'sTA's Avatar
T T T
Old Mar 6, 2006 | 10:33 PM
WHITE DEVIL's Avatar
Qa-1s, do you still have them send me pm please
Old Mar 7, 2006 | 12:13 PM
camaro85's Avatar
what are the flow # on the heads?
