Where to find metric adapters??
Old Mar 6, 2006 | 09:23 AM
Jhankinson's Avatar
Default Where to find metric adapters??
I am trying to find a place where I can get a 1/4" npt female to M16x1.5 male adapter for the oil pressure sending unit. I need to switch it over from the LS1 sender to the one originally on my S10. That way the gauge works properly and the fuel pump safety is in effect still. I am trying to make this all work as stock.... Also I am trying to find an adapter for the temp sender...to put the factory S10 temp sender in the passenger side head. I dont know yet what thread pitch the original S10 sender is...but I know it is M12x1.5 on the head. So if anyone can chime in on this I would be very much abliged.
Thanks.....Josh-
Old Mar 6, 2006 | 09:43 AM
Brains's Avatar
I made one from an old broken sending unit. I simply drilled out the fitting and tapped it 1/4" NPT. I think I have another one I could convert and sell if you can't find one locally.
Old Mar 6, 2006 | 10:21 AM
HSV-GTS-300's Avatar
Can only find 1/8NPT female to M16 male.....but here's a starting point for you.
Sunpro
Autometer
Equus
Stewart Warner
http://www.sw-performance.com/produc...yid=69&ispod=0
http://www.sunpro.com/product_detail.php?pid=16338
http://www.autobarn.net/eqoilpreselt.html
http://www.martelbrothers.com/catalo...p-1-c-488.html
Old Mar 6, 2006 | 10:46 AM
Jhankinson's Avatar
Brains how much you want for it? I might be interested....finding one is not going to well here.
Old Mar 6, 2006 | 11:06 AM
under pressure's Avatar
I would suggest calling Orme Brothers in California for your fitting (818-885-1414). These guys are a warehouse distributor for many product lines of connectors and AN manufacturers. If that doen not work, VDO used to carry some of these style adapter fittings in their product catalog. Good luck. Mac
Old Mar 6, 2006 | 11:27 AM
Brains's Avatar
$10 shipped sound ok? Just have to find it in the bottom of my tool chest
Old Mar 6, 2006 | 12:23 PM
MrDude_1's Avatar
whoa.. that adapter is going to be just a thinly threadded ring.. lol
you could easily take a metric to 1/8" NPT fitting and drill it out, tap it and fit that fitting in it...
Old Mar 6, 2006 | 12:32 PM
Brains's Avatar
Its thicker than you think
Old Mar 6, 2006 | 01:41 PM
MrDude_1's Avatar
well, lets see.
1/4" = 6.35mm
16mm - 6.35mm = 9.65..
9.65 / 2 = 4.82500
so you have about a 4.5mm thick ring around the edge of the adapter... plus the width of the hex head... yea, thats not as thin as i first thought.
(and yes, im bored)
Old Mar 6, 2006 | 02:55 PM
Brains's Avatar
Well, its less than that ... 1/4" NPT has a thread size very close to 1/2"-18 (.490" to be exact). The drill size is 7/16" (ie. hole size before tapping).
Old Mar 6, 2006 | 05:11 PM
86MonteSSLS-1's Avatar
Try this out !
Old Mar 7, 2006 | 09:31 AM
Jhankinson's Avatar
Hey Brains PMed ya on this one
Old Mar 7, 2006 | 08:59 PM
Brains's Avatar
FYI, here's what it looks like (yes Josh, this is yours)
Old Mar 9, 2006 | 10:00 AM
vortec_7's Avatar
what size socket fits the hex head on the LS1 sender?
Old Mar 9, 2006 | 11:03 AM
Brains's Avatar
Can't remember off the top of my head, but its like 22mm or somewhere around there.
Old Mar 9, 2006 | 12:11 PM
Jhankinson's Avatar
the normal 1-1/16" oil pressure socket worked for me just fine....they sell them at about every autoparts store....some are 1" to 1-1/16" socket....thats what I got and its perfect fit.
Josh-
Old Mar 9, 2006 | 12:46 PM
MrDude_1's Avatar
Josh-
thats what i always use... if i use anything else, i usually break it. lol
Old Mar 23, 2006 | 01:19 AM
red90cobra's Avatar
Originally Posted by 86MonteSSLS-1
looks like theres a fitting there that works
