Richmond 4.10 gearset "thick cut" for 2 series carrier $150
Richmond "thick cut" 4.10 gearset GM 10 bolt 7.5-7.625" gears, for 2 SERIES CARRIER(POSI).
2-Series = 3.08 and numerically lower carrier.
This would be for a 2.73 geared or 3.08 geared fbody. Will not work with 3.23 or 3.42 cars unless you switch back to the 2 series carrier. See below for other applications.
Fits: 77-02 All GM models, 82-02 Camaro/Z-28/Firebird/Trans-Am, 83-02 S-10/S-15 (rear), 85-02 Astro/Safari, 77-87 El Camino (Will not fit Monza, etc.)
I had Scott @ Driveline Solutions (sponsor) have a a look at these. There is some loctite on the pinion threads, but it doesn't look like a bearing was pressed on so he assumes the gears are new. They look great to me too.
$150 shipped
$150 shipped
