Polished Taillight center
Old Mar 31, 2006 | 06:33 PM
ScottWS6's Avatar
Default Polished Taillight center
Who has done this? How and what did you use to do it?
Old Mar 31, 2006 | 07:17 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Search is your friend...
https://ls1tech.com/forums/showthrea...ight=taillight
https://ls1tech.com/forums/showthrea...ng+bird+emblem
Old Mar 31, 2006 | 07:29 PM
ScottWS6's Avatar
Thanks. I forgot about doing a search.
Old Mar 31, 2006 | 08:03 PM
y2k_ta's Avatar
'Bird Director
That's ok....it took me several different attempts at finding those links myself. The obvious key words weren't turning up any results
Old Mar 31, 2006 | 09:02 PM
PontiacFan's Avatar
From that thread, ...
(From some of my previous posts, ...)
I've done literally DOZENS of these things over the last couple years, ..., & have one in stock right now for sale.
I start with a 600 grit, keeping it wet, using a small 1/4 sheet sander.
Then on to 1200-1500 by hand, then finish by hand with 2000 grit, keeping them wet while sanding to wash away the contamination.
Then I use an old Black & Decker orbital polisher with Zaino's Glass Polish first, then on to the Zaino Plastic Polish.
They turn out excellent. Beautiful glossy shine. Had a guy one time, complained that it didn't match the taillights now because of too much shine! So he sent me the taillights to polish them also!
You'll get the same/similar description by most anyone else who has done it. Although some may not put that much work into it, .... You can also use other brands of polish. I've tried others, but didn't get the same quality results as I do with the Zaino process.
Good Luck!
(By the way, I do all this with the units screwed down to my temp workbench work surface. Not on the car.)
And yes, you can buy them from GM without the text & bird already. But they'll cost ya twice as much or more depending on the style you want.
All from GmPartsDirect.com
Firebird tail filler panel (from 93-97 Firebird V6) = 5977293---------------------$105.60 w/s&h&tax
Firebird tail filler panel (from 93-97 Formula) (plain black - no logo) = 5977294--$102.13 w/s&h&tax
Firebird tail filler panel (from 94 25th Anniv TA) (white logo) = 5977296--------- (Not available anymore)
Firebird tail filler panel (from 93-94 Trans Am) = 5978095----------------------$100.72 w/s&h&tax
Firebird tail filler panel (from 95-97 Firebird 3800 GT V6) = 5978095-------------$100.72 w/s&h&tax
Firebird tail filler panel (from 95-98 Trans Am) = 5977286-----------------------$95.65 w/s&h&tax
Firebird tail filler panel (from 99 Trans Am) = 5978095--------------------------$100.72 w/s&h&tax
Firebird tail filler panel (from 99 30th Anniv TA) (white logo) = 16525477--------$97.70 w/s&h&tax
Firebird tail filler panel (from 00-02 Trans Am) = 5977286 ----------------------$95.65 w/s&h&tax
Firebird tail filler panel (from 02 CETA) (silver logo) = 10312725-----------------$108.09 w/s&h&tax
Good Luck, Hope this helps even more!
