Tail Lights Condensating
Old 04-04-2006, 08:48 PM
7901 WS6's Avatar
Default Tail Lights Condensating
My 94 t/a tail lamps are taking in water from like a car wash or rainfall. It drys up inside when sitting in the sun. So I know there is air getting in/out. I need to know how to disassemble them so I can make a seal. Any thoughts.
Ive done this before on my 79 t/a tail lamps and a 3rd gen once but I cant figure out how the front lens pops off. Now water is not getting into where the bulbs are, it is in front of that plastic core part. Or Should I leave them till Dry and run a bead of rtv silicone all around??
Old 04-04-2006, 08:54 PM
BigDaddyBry's Avatar
Same problem here. Driver's side only. Looking to crack mine open this weekend.
Old 04-05-2006, 06:43 AM
blackbirdls1's Avatar
I have the same problem on the right side for me, its too late to seal it, its not getting any worse, I will probaly do a blackout or replace it and seal it off good.
Old 04-05-2006, 10:39 AM
I was thinking of cracking it open and trying to clean it out.
Old 04-05-2006, 01:16 PM
I don't think that will fix anything, these problems are common in T/A firebird taillights.
Old 04-05-2006, 01:34 PM
It won't fix the condensation, but there has to be something causing the darkening of my taillight. Mildew, mold, etc. I'll find out when it's open and if it can be cleaned.
7901 WS6 and I are speaking about a different, but related subject. Sounds like he wants to prevent it, I want to fix then prevent, since I have the discoloration.
Old 04-05-2006, 09:36 PM
thechef's Avatar
i had the same problems my tail lights looked like fish tanks
at night you could see the water slosh around when i turned corners
take them off and drill a small hole in the bottom of each section and put them back on it will allow them to drain and keep the condensation away
Old 04-06-2006, 11:00 AM
7901 WS6's Avatar
I going to take a look at them again this weekend and see if there is a way to dimantle them(without craking them) and find out how water is getting in. I think there may be some snaps or plastic clips that hold the lamps together. Also get some new rubber washers for the wiring harness bulbs.
Old 04-06-2006, 11:33 AM
peterlawl84's Avatar
i had the same problem with my tailights and foglights on my 99 t/a. after replacing the foglight assembly a couple times, my friend showed me the lights on his mercedes had a small hole in the bottom of the assembly to allow for water to drain out. i drilled small holes in each of the assemblies and havent had any problems with water collecting or blackening of the lens/dulling of the metallic reflecters. that was 2 years ago and the car is a daily driver, so it sees alot of rain.
Old 04-06-2006, 01:38 PM
Good ideas guys.
Quick Reply: Tail Lights Condensating
