Advanced Engineering Tech For the more hardcore LS1TECH residents
#7 Piston Failure FIX !!!
Old 04-06-2006, 07:22 AM
gollum's Avatar
Default #7 Piston Failure FIX !!!
I found this tip reading Will Handzel's book How to Build High-Performance Chevy LS1/LS6 V-8's.
When GM started using the LS6 Intake manifold they omitted the rear steam vent tubes on rear of heads and used only a front vent tube version because of clearence issues with the lower floor of the LS6 manifold. Some road racers say blocking off the rear steam ports will cause detonation and damage the #7 piston. Here is the cure and I quote from book:
"TIP: Some road racers have been using the pre-LS6 steam tubes underneath the LS6 intake to improve cooling in cylinder number 7 (they previously had detonation problems in that hole). While the pre LS6 rear steam version was not used on factory LS6's, they will fit under the intake by slightly grinding down some of the stiffening ribs on the bottom side of the intake. Some racers just install the steam tube component and, during rebuilds, find some small indentions where the ribs come in contact with it and grind away for clearence."
Can we use the pre LS6 vent tube with the FAST intake?
Homer_Simpson (01-02-2022)
Old 04-08-2006, 05:46 PM
MrDude_1's Avatar
thats not a fix. the problem of the #7 cyl getting the most air isnt solved... it just reduces the odds if you're on the edge by keeping that rear cyl cooler.
Old 04-14-2006, 03:23 PM
'02 SLP#686's Avatar
I bought a motor that had a D1SC on it and then a 76mm STS system, when I tore it down #7 was missing some of the top compression ring... thanks for the info The motor only had about 10K on it too.
I definately think it would have made a difference on his car, my car is N/A however and the motor is already in otherwise I would have put it in there for the piece of mind.
Old 04-17-2006, 06:51 PM
FASTFATBOY's Avatar
Just wanted to throw this out there..I have seen 3 LS1 cars with a random misfire on #7, one with a dead miss, with the fuel system being a "dead head" system(no return to tank)...I tore down the fuel rails on all 3 cars....all cars were FULL of trash in the rear drivers side of the rail(#7)..all 3 cars were fixed with a cleaning and clean injectors. They picked up SERIOUS amounts of power.
Maybe look at this in the future.
David
Old 04-17-2006, 07:19 PM
Zymosis's Avatar
David
What did you use to clean injectors/how was it done?
Old 04-17-2006, 07:25 PM
FASTFATBOY's Avatar
I sent one set to get cleaned locally, bought used injectors the other two times, it was cheaper.
David
Old 04-17-2006, 07:27 PM
brad8266's Avatar
what was used to clean the rails?
Old 04-17-2006, 08:53 PM
FASTFATBOY's Avatar
Brakeclean and or carb cleaner and an airhose.
David
Old 04-17-2006, 09:17 PM
Cheatin' Chad's Avatar
That's definitely a good thing to keep an eye on but I think part of the #7 failures has to do with the cooling system. I've got a Silverado SS sittin' at my shop with 18,000 miles and a spotless fuel system with the #7 piston blowed the f#@k up.
Old 04-17-2006, 09:19 PM
SHINER's Avatar
how do i clean m fuel rails and injectors????
Old 06-07-2006, 08:38 PM
14 Second Truck Club
mzoomora's Avatar
My 10k mile 04 Silverado is in the dealer now with a blown No. 7. It was showing misfire codes on and off for about 6 months and using oil. I guess a D1 at 11 psi on a stock motor can do that.
MadBill's Avatar
How about welding a bung in the #7 primary and seeing if the AFR is lean of the left bank average?
Old 06-07-2006, 08:44 PM
99Custom's Avatar
David
My 99 ls1 with only 21,500 at the time (2 months ago) had the same problem...the #7 injector was plugged full of crap...It eventually ruined the plug, cat's, coil before i figured it out....But hey...I got all new parts and runs strong now....I'm gonna post some pics of thatinjector...it was nasty..
Old 06-11-2006, 09:43 PM
Mrs. Ronin's Avatar
We are having problems with #7. The shop says there is no compression there and the car smokes like a chimney. The shop wanted $3000+ to take the engine out and then whatever the shop they sent it to would charge for the machine work, THEN MORE money to put the engine back in! I can't afford that!
So any suggestions what should we do. This problem with the #7 cylinder......should we replace the block? What causes it, I see some say, dirty injectors, air inequalities, ect. Our car has a Vortech supercharger, a Bullet racing cam, 36# injectors, and a whole mess of other things. I would really like to get it running.
Old 06-17-2006, 07:42 PM
Dave88z's Avatar
Has anyone contacted a dealership, or a dealer tech? I bought a used 6.0 LQ4 w/ 10k on it. Everything looked MINT...until the heads came off
#7 was scored and pitted. Delivered the motor to a sponsor to check it out (now going 408 ) and they said GM was replacing a **** load of motors due to
an oiling issue. I would assume the lack of oil was allowing #7 to get tight and break rings. I'm sure the cooling/clogged injector thing doesnt help either.
What do you guys think
Old 06-17-2006, 08:07 PM
98Z28MASS's Avatar
You can get a brand new 346/347 forged shortblock from a sponsor for under $3000. Look at texas-speed, SDPC, FFHP, etc...they all make some stout short blocks.
Old 06-17-2006, 08:48 PM
JMBLOWNWS6's Avatar
I feel that the vic JR intake solves this problem.
Old 06-17-2006, 09:02 PM
mr2guru's Avatar
this is what I am going to do on motors I build that run standard LSx style intakes.
Fab rear steam tubes and flow injectors putting the strongest on #7.
Old 06-17-2006, 10:54 PM
ArcticZ28's Avatar
That's what typically most people do when stepping up from stock injectors for higher hp apps.
Old 06-17-2006, 11:05 PM
ex-SS-ve's Avatar
fuel rails are simple. as are the injectors. got to hook up a injector cleaner to the rails. holler at me if you got any questions.
Quick Reply: #7 Piston Failure FIX !!!
