> > > - Racetronix 32 lb/hr Injectors - < < <
Old Apr 19, 2006 | 05:44 PM
TAQuickness's Avatar
Thumbs up > > > - Racetronix 32 lb/hr Injectors - < < <
Racetronix 32 lb/hr Injectors like new with ~5k miles. O-rings were lubricated immediately after removal. SOLD! Prefer PayPal. No dibs.
Please PM for fastest response.
From the Racetronix website:
Part Number Delphi D17208A (Lucas old 5207009, Lucas New 621020)
Static Flow Rate @ 43.5PSI (300kPa) = 31.6 lb/hr = 332cc/min = 239g/m
Static Flow Rate @ 58.0PSI (400kPa) = 36.5 lb/hr = 384cc/min = 276g/m
Dynamic Flow Rate @ 43.5PSI (300kPa) = 6.68 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Dynamic Flow Rate @ 58.0PSI (400kPa) = 7.72 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 16.2 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Physical Dimensions > CLICK HERE <
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
Edit: Lowered price.
Old Apr 21, 2006 | 04:26 AM
morning bump
Old Apr 21, 2006 | 09:33 AM
fbodyls1ws6's Avatar
so will that fit a 95 Trans am
Old Apr 21, 2006 | 11:47 AM
I'm not sure. You could email Racetronix (sales@racetronix.com) and ask them if the part number is compatible with your application.
Old Apr 21, 2006 | 01:01 PM
ok.....
Old Apr 25, 2006 | 03:31 PM
Afternoon Bump
Old Apr 25, 2006 | 04:16 PM
muff daddy's Avatar
you have a pm
Old Apr 25, 2006 | 06:19 PM
pm replied to
Old Apr 25, 2006 | 06:51 PM
muff daddy's Avatar
another one...
Old Apr 25, 2006 | 07:37 PM
replied again...
Old Apr 25, 2006 | 08:52 PM
muff daddy's Avatar
sold!!
