Patriot 59cc Heads with Dual Springs and Ferra Valves
Old Apr 25, 2006 | 04:53 PM
Rescue Ranger's Avatar
Default Patriot 59cc Heads with Dual Springs and Ferrea Valves
Up for Sale:
Patriot 59cc Heads with all the options;
Dual Valve Springs
Ferrea Valves 6000 Series 2.02/1.57
All the new guides/seals etc.
PLUS: Gunnar is throwing in new GM Head Bolts no charge
*edit* SOLD
Old Apr 25, 2006 | 04:59 PM
y2k1blkss's Avatar
so these are LS6 heads? What cam were you running with those dyno numbers? rocker arm ratio? stock bottom end? stock push rods?
Old Apr 25, 2006 | 08:12 PM
LS6 style stage 2 casting with Ferrea Valves. Check www.patriot-performance.com for specific information on these.
I had hardened pushrods (this doesn't add power - its a safety feature)
224/228 113+0 .581/.588 Comp Cam
Stock bottom end, stock rockers.
Old Apr 25, 2006 | 08:24 PM
just-a-z's Avatar
Stock size valves or 2.02 1.57?
Old Apr 25, 2006 | 08:27 PM
Edit: They are the 2.02/1.57 Ferrea valves.
Old Apr 25, 2006 | 11:08 PM
Bump!
Old Apr 26, 2006 | 08:29 AM
VORTECFCAR's Avatar
why are you selling so soon? You sounded pretty happy with the setup!
curiousity has the best of me.
Old Apr 26, 2006 | 08:42 AM
I made an impulse buy and got these high compression heads, and even though they made a lot of power - I have an opportunity to get a set of lower compression heads to start a platform for something that I really wanted to do in the first place. I'm buying another different set of patriot heads to replace these, which is why Gunnar is going to take these back and make sure they're new before going to the buyer. Its a work-in-progress
Old Apr 26, 2006 | 12:42 PM
Gunnar@Patriot's Avatar
We will go through and check these out for the buyer and make sure they are good to go. There will be no charge for this and we will also include a set of oem head bolts.
Old Apr 26, 2006 | 04:12 PM
I had some PMs, I replied to them.
Old Apr 26, 2006 | 04:15 PM
JL ws-6's Avatar
Race your car!
Surprising to see you changing it so soon... you're results were good. Good luck with the new setup though.. I assume that one of those bottle setups that Eastside is famous for will be making it in eventually
Old Apr 26, 2006 | 05:37 PM
Z28FirefighterI1's Avatar
Did you have any PTV problems? Fly cut?
Old Apr 26, 2006 | 08:30 PM
None at all. No PTV issues and no flycutting. I was going to put a F13 in; it would've cleared fine. I went with a 224/228 cam because its what East Side recommended for a stock displacement engine.
Old Apr 26, 2006 | 09:10 PM
I should also note that these heads are not milled down!
Old Apr 27, 2006 | 09:32 AM
Bump for the AM crowd!! Come on guys, brand new heads, for SO MUCH OFF, with new bolts! Make me a good offer I want these sold!
Old Apr 27, 2006 | 03:52 PM
Bump for the dinner crowd!!
Old Apr 27, 2006 | 07:05 PM
PM sent.
Old Apr 27, 2006 | 07:40 PM
GQ's Avatar
GQ
pm sent
Old Apr 27, 2006 | 10:40 PM
All PMs replied to. Thanks
Old Apr 28, 2006 | 02:29 PM
Originally Posted by G's99_hawk
pm sent
Greg, I left you a voicemail.
These heads are still available!
