C5R 427 twin turbo pis...progress
Coming along nicely
SPECS: C5R, 427 ci, Mahle custom turbo pistons, forged magnum X-S callies crank, Oliver billet rods, ET performance heads with Iconel exhaust valves, 8.6:1 compression custom turbo cam (cam motion),
A-1 technology MP-35 270psi studs ($1000), cometic gaskets, Fast intake, NW 90mm billet TB, Throttle wire conversion, Big stuff 3 engine management with stock piggy ECM (all functional gauges), PTK turbo system, Ceramic coated (not powder coated) pipes with internal 1800 degree "race" coat, All ARP stainless polished fastners, Evans waterless coolant, BeCool radiator, 67mm twin precision turbos, coated 2000 degree exhaust housings, Iconel custom heat shields, Magna fuel external custom fuel system (completely "as stock" fuctional..maintained intank bucket only has a "pickup" with F-Body venturi pump (no intank pump), -10 feed .. -8 return, Magnafuel billet regulator, completely built trans (all upgrades possible), Yank SC3000 1400hp converter with 5 bolt flexplate, custom Peterson crankcase ventalation system -12 plumbing, Lingenfelter battery relocation kit, relocated coils, EBoost2 electronic boost control, MUCH MUCH more.
Tom Ulrich
Tom Ulrich
Holy Snikies! That's going to make awesome power. Can't visualize the air filter/intake plumbing with that water pump, but I'm sure you have it figured out. Between the displacement, those ET heads and the turbos, you are going to be moving some serious air through that baby. Wow...
Originally Posted by tomulrich
Coming along nicely
Edit lol! I know the reason as I looked again, the operator won't fit. A space savings for sure.
Originally Posted by Goonie
looks like nothing is stock... no washer fluid nor coolent resovoirs... i love it
Thats the same kit im going to run. The coolant resovoirs are relocated to where the battery is.
