Moser 12 bolt/spool 33 spline
I have a MOSER 12 bolt that im looking to possibly sell. Its a 33 spline with a spool, 1350 yoke, 1/2 studs ( long ones ) and a TA cover. No ABS/TCS . It also has a BMR extreme duty anti-roll bar that comes with it since the brackets for the bar had to be welded on. If you price out a 12 bolt with the options it has you're looking at almost $2300 and then the $350+ anti-roll bar on top of that. The only thing you will need is the body brackets that weld to the body for the anti-roll bar from BMR or Spohn sells some bolt in ones. I am also willing to throw in a stock aluminum drive shaft with the correct u-joint for the 1350 yoke or otherwise you will need to pick one up at a local parts store and get it pressed into your drive shaft which means down time. LOCAL PICK UP ONLY so please dont ask to ship it. Im from the chicago land area. My price which is firm is $1,900 FIRM due to the items that come with it.
Originally Posted by Tapout911
If you change your mind about shipping, let me know. I have cash but no desire to drive 11 hours to pick it up.
