Some extra stuff to sell, gaskets, timing chain...
Old May 4, 2006 | 01:47 PM
GFORCE1320's Avatar
Default Some extra stuff to sell, gaskets, timing chain...
I have some stuff left over from a couple cars that I need to sell. some new, some used.
new - Fel-Pro head gaskets for LS1 (pair) $35.00 **SOLD**
new - GM steel laminated 6.0 ltr head gaskets $50.00 **SOLD**
new - Sealed Power stock replacement timing chain set (LS1) $65.00
new - Hastings LS1 stock bore molly rings (non-file fit) $145.00
new - Clevitte 77 LS1/LS2/LS6 P series main bearings $60.00
new - ACL LS1/LS2/LS6 rod bearings $12.00
used - Ex. manifolds off of 05 GTO $75.00 **SOLD**
used - LS2 05 GTO stock cam $75.00
used - LS2 05 GTO stock rods and pistons $175.00 **SOLD**
used - LS2 05 GTO stock push rods $25.00
Used - LS2 05 GTO stock main bolts $25.00
Everything is plus shipping.
If you need photo's let me know and I'll email them to you.
Old May 4, 2006 | 02:22 PM
ls1stang's Avatar
Sent you a pm on the gasket, timing set, bearings, and rings.
jamie
Old May 4, 2006 | 02:32 PM
GFORCE1320's Avatar
PM'd ya back and added rod bearings to the list.
Old May 4, 2006 | 02:40 PM
marv's Avatar
How do these compare to the OEM/Stock gaskets? Same thickness, etc?
Thanks.
Old May 4, 2006 | 03:16 PM
GFORCE1320's Avatar
I'm pretty sure the GM gaskets are .056 but not sure on the Fel-Pro's.
Old May 4, 2006 | 08:08 PM
GFORCE1320's Avatar
the top for the evening
Old May 4, 2006 | 08:26 PM
2002B4CCamaro's Avatar
Is that an LS2 timing chain?
Old May 5, 2006 | 09:39 AM
GFORCE1320's Avatar
LS2 and LS1 should be the same but if I'm wrong maybe someone will correct me.
I better be right because I have a LS1/LS2 billet chain set in my LS2 402.
Old May 5, 2006 | 10:05 AM
The gears are the same, the LS2 chain is alot better. On TSP's website you can see the difference. Less slack.
Old May 5, 2006 | 12:45 PM
GFORCE1320's Avatar
The one that I have for sale for an LS1.
Old May 6, 2006 | 02:21 PM
GFORCE1320's Avatar
bumpty bump
Old May 8, 2006 | 04:15 PM
GFORCE1320's Avatar
Head gaskets are sold.
Old May 9, 2006 | 06:26 PM
GFORCE1320's Avatar
I've still got some good stuff here for sale.
Everything that's left over will all be going on Ebay tonight.
Old May 12, 2006 | 09:50 AM
GFORCE1320's Avatar
Rods, pistons and manifolds are sold, still got some stuff left.
