RollMaster Double Roller adjustable Timing set, CHEAP!!!
Old May 14, 2006 | 07:13 PM
BLUE35THSS's Avatar
Default RollMaster Double Roller adjustable Timing set, CHEAP!!!
Rollmaster Double-Roller Adjustable Timing Set
This double-roller timing-chain set is a perfect complement to our high-performance camshafts and other LS1/LS6 engine components. It offers greatly enhanced strength and accuracy compared with the stock piece and even allows for timing adjustments (advance or retard) of up to 8 degrees. The set contains an adjustable, nine-keyway nitrated crankshaft sprocket; a double-row chain; a nitrated camshaft sprocket; two oil-pump-spacer plates; detailed instructions; and all necessary installation hardware. Compatible with all 1997-03 "Gen III" engines (LS1/LS6, 4.8L, 5.3L, 6.0L).
Barely used, only on the car for a few hundred miles...
$75 plus S/H
Old May 15, 2006 | 08:37 AM
BLUE35THSS's Avatar
Default Price Reduced
Need to get rid of this... Car is sold... Dont have a need for it anymore...
First $50 plus s/h takes it...
jm
Old May 15, 2006 | 08:41 AM
Friday13th's Avatar
Interested........sending pm
Old May 15, 2006 | 11:20 AM
BLUE35THSS's Avatar
Sold!!!!
Old May 18, 2006 | 09:53 PM
Friday13th's Avatar
Received the chain today. I left feedback for you.
Thanks again, Shaun
