Here's my (stealthy) install.
Old 05-15-2006, 09:07 PM
keliente's Avatar
Default Here's my (stealthy) install.
I happened upon a NOS 5177 kit very cheap, so I figured why not. This stuff is pretty fun - I have hit it on the highway once and at the track for a few passes. It's so crazy how I'm pressed back against the seat when it comes on.
I don't plan to jet higher than 100, because as I said, it's just something to play around with. The reason I did my install like I did is because I don't really like the look of wires and solenoids hanging out everywhere. I understand some of the more hard-core kits can't be hidden, but I just hate sloppy installs.
I also wanted to hide it for a stock appearance, because 99.9% of the time it's just a cam car at the track. I wouldn't want people seeing all the n20 under the hood and thinking that's what's getting me down the track.
It took a bit of planning to get things the way I wanted, but I got it figured out in the end. I started by mounting the solenoids in between the radiator and the plastic shroud, and snaked the lines upward so that they come through the filter.
Sneak peek at the lines/solenoids:
The filter (since revised)
The solenoids get n20 from a feed line on the left side of the engine bay, which is inconspicuously covered in convolute tubing. It runs through the PCM grommet into the cabin of the car.
Then the line is hidden under the door sill.
Because it's not really a permanent fixture in my car, I mount the bottle behind the passenger seat. That eliminates my need for a remote bottle opener, and when I throw a coat over it no one is the wiser.
My remote bottle opener:
I chose a regular pilled MSD window switch and an electronic WOT switch from harris speed works. I put these in the center console, along with the purge button and arming button. BTW, it purges towards the ground under the car, unnoticeably. I use the burnout box to cover the sound. When I am not using the nitrous, I put a plastic shelf into the console so that I can put regular items in that compartment without bumping any switches.
All of my wiring runs up the right side of the engine bay, also covered in convolute tubing.
Overall this setup has been very fun. Before I had the cam, I dynoed around 445hp on a 75 shot. It's definitely a nice kick in the pants!
The end result: nothing obvious in the engine bay. At the track, some people caught onto the high mph I was turning, and asked if I had n20. I said if you can find it....
Whatcha think?
Old 05-15-2006, 09:36 PM
BadROC's Avatar
definately cool, good work meng!
Old 05-15-2006, 09:41 PM
71camaro's Avatar
Yeah I bet it took a while to do all the work, Nice though, very nice!
Old 05-15-2006, 09:53 PM
co.6z28's Avatar
nice work...your one of the coolest chics around
Old 05-15-2006, 10:11 PM
1 BLOWN V8's Avatar
Awesome job. I like how you ran the wire loom on the side of the fender.
Also where do I purchase that cool remote bottle opener you have.
Old 05-15-2006, 10:27 PM
keliente's Avatar
Oh don't make me blush.
Old 05-15-2006, 10:29 PM
brad8266's Avatar
Nice stealthy setup.
Old 05-15-2006, 10:31 PM
NitrousDirect's Avatar
Good job man! And nice photo narration
Old 05-15-2006, 11:00 PM
Somebody09's Avatar
Originally Posted by keliente
Ok, when I saw this, I just lost it! Anyone else "get it"?
Old 05-15-2006, 11:23 PM
Restricted User
CAT3's Avatar
Yes.
And very nice looking setup, or not so looking good setup
Old 05-15-2006, 11:27 PM
Yup..
Old 05-15-2006, 11:57 PM
keliente's Avatar
Pervs!
calongo_SS's Avatar
Good job, but the jacket over the bottle thing is a little lame. If the rest of the kit is hidden, hide the bottle too.
Old 05-16-2006, 12:03 AM
dre2013's Avatar
i like!
Old 05-16-2006, 07:23 AM
keliente's Avatar
I suppose I could, but behind the seat is so easy.
Old 05-16-2006, 09:42 AM
Turo's Avatar
I really like your console setup. I was thinking of redoing some of my wiring and moving all my switches in there, but I was afraid of one getting activated or something when I have things in the console. Does your plastic shelf also cover the switches you have on there? If so, do you have any pics of it? I'm curious about it...
By the way, we have the same style remote bottle opener .
Old 05-16-2006, 10:22 AM
Nitro Dave's Nitrous Outlet's Avatar
Nice clean install. Good job.
Dave
Old 05-16-2006, 10:49 AM
keliente's Avatar
I'll have to grab a pic later. You know how in the console there is sort of a 'ridge' that goes around it about 3-4" from the bottom? It rests on that. It covers everything. The arming switch has a cover on it anyway in case it got bumped.
Old 05-16-2006, 10:51 AM
Hennytime's Avatar
im redoing my wiring this weekend, and if anyone has seen it at OSW, its the wrost clusterfucked rats nest ever, but it will be nice, 50' of wire loom mightb e some over kill but whatever!
Old 05-16-2006, 11:21 AM
BadAssFast's Avatar
Not bad for a girl. LOL.
Quick Reply: Here's my (stealthy) install.
