View Poll Results: how many are using a lc-1 and how many are screwed up
yes i have one and it works great
58.86%
yes i have one and its broke or has broke
41.14%
Voters: 175. You may not vote on this poll
how many are using a lc-1 and how many lc-1's are broke?
Old 05-18-2006, 01:45 PM
7 Second Club
ty_ty13's Avatar
Default how many are using a lc-1 and how many lc-1's are broke?
i just wanted to see a poll of a ratio from good to bad
Old 05-18-2006, 02:09 PM
joecar's Avatar
Things that can break a working LC-1:
a. shorting either of the analog outputs to power or ground.
b. flashing new firmware to it (don't do this).
I understand there's a bad batch from the factory, it's giving the LC-1 a bad rep.
Old 05-18-2006, 02:16 PM
chrisj6's Avatar
a bad batch? How many bad batches? Mine has cooked twice following their grounding instructions.
Chris
Old 05-18-2006, 02:21 PM
horist's Avatar
they posted up that they're selling between 1500 and 2000 a month so a bat batch could be quite large
I installed mine using some spare parts from my LM1 and only problem I have is every once in a while it'll overheat (it's in my collector)... installing a new bung and heatsink should resolve it
Old 05-18-2006, 03:20 PM
bmfcamaro's Avatar
seems the early ones are the best. yeh!
Old 05-18-2006, 05:51 PM
slow's Avatar
I installed one, had the XD1 gauge, and LC1 on seperate power switches, and could never get it to work right. Uninstalled it 24 hours later.
I then connected it portable, with a direct battery connection, it appears to be stable about 70% or so, of it powering up and registering stoich airfuel.
I have always hated Bosch sensor based widebands, since they're questionable due to sensor drift over time.
I wish I could justify a AFM1000 like I use at work and be done with it, but since I can buy 8-10 LC1's for what it costs, it's hard to do, when I don't do private tuning.
Ryan
Old 05-19-2006, 06:25 AM
99whitews6's Avatar
Nothing but problems
Old 05-21-2006, 08:00 PM
7 Second Club
ty_ty13's Avatar
This poll makes me
Old 05-21-2006, 08:18 PM
redtail2426's Avatar
i just installed one yesterday on my car including an xd-1 and its worked perfectly so far.
Old 05-21-2006, 08:33 PM
98SS2836's Avatar
installed mine today with an XD1 works mint Follow instructions to the T.
Old 05-21-2006, 09:25 PM
Chris81's Avatar
I've got three now, the first one on my car has a bad analog out, so I can't record with it but otherwise it works fine.. then I have another one that I use on other people's cars that has worked great so far.. and now I have another one for my car that I haven't put on yet. I plan on sending my first one back to get worked on soon.
Old 05-21-2006, 09:30 PM
7 Second Club
ty_ty13's Avatar
will these guys fix their faulty product for free?
Old 05-22-2006, 12:11 AM
SmaknaSS's Avatar
Wow! 37% are broke?
Old 05-22-2006, 01:16 AM
Chris81's Avatar
I don't know, but I intend to find out. Hopefully so, if not i'll be pretty upset since I do own THREE of the damn things, lol.
Old 05-22-2006, 10:16 AM
horist's Avatar
I drove my car this weekend for 400 HARD (car club cruise... RPMs never below 3000 RPM speeds rarely below 60, lots of twisties, lots of WOT, etc...) miles this weekend
Never once did it go into overheat mode... main difference? I had the subwoofer turned off (listening to FRS radios to keep up w/oncoming cars etc...)
so seems it's very voltage dependent... a drop and it'll hiccup .... I haev an ASP underdrive pulley, stock alternator pulley... I may install an alternator overdrive pulley soon to see if it helps
Old 05-22-2006, 05:54 PM
pwrtrip75's Avatar
Ive the same one on 2 cars so far....not a single prob.
Old 05-22-2006, 07:44 PM
7 Second Club
ty_ty13's Avatar
this is an interresting hypothesis... let me know
Old 05-22-2006, 11:02 PM
Okie5.3's Avatar
used the first one less than a week and got the infamous 8-flashes for the timing error. new one still going so far.
Old 05-23-2006, 12:12 AM
Jpr5690's Avatar
Mine Started Smoking The Other Night Ive Had Nothing But Trouble With Mine To Say The Least Im Not Impressed Not To Mention The Cust Service Was Kinda Rude
Old 05-23-2006, 02:23 PM
LS1TECH Sponsor
DynotuneN2O's Avatar
Wow... interesting post. Let me add some insight if I may. We are Innovates largest LC1 distributor in the country by far so I can give you the lowdown first hand as we have seen it all.
Here is what we have seen - for every 100 units we ship out we typically have 10 - 15 with problems. Typically we eliminate 50% of the problems over the phone as they are typically wiring or grounding issues. Of the other 7 or 8 we have those sent back to us. Typically 50% of those that come back work perfectly. We have a test bench in house to fully test the units. In some cases we ship the customer a brand new unit incase there is a possible intermittent issue. We then sell these at discount and I cannot remember one that has come back. The remaining 3 or 4 do have hard failures and typically it has to do with the outputs failing or tieing up or an application/customer issue. We are told the new revision fixed this issue. The new revision will ship in volume the end of this month. We have seen that so far but we will wait and see.
We have no tie to Innovate - we chose to integrate them with our gauges as the design and performance has been the best from all the units we have tested. Dynotune has 1000's of these units in the field in cars - trucks - ATV's - speedboats - bikes - Jet Skis - Snowmobiles and the list goes on.
Hope this helps!
Dean
www.dynotunenitrous.com
Quick Reply: how many are using a lc-1 and how many lc-1's are broke?
