roadmaster and f-body lt1 engine differences?
Old 05-25-2006, 07:49 PM
LS1-SEVEN's Avatar
Default roadmaster and f-body lt1 engine differences?
Like the title says, what are the differences between the roadmaster and f-body lt1 engine? Because I have a roadmaster lt1 that I am rebuilding and I will be dropping into a RX7. I need to make sure all lt1 parts are innerchangerable.
thanks
Old 05-25-2006, 08:08 PM
NotACop97Z's Avatar
Look up the LT1 FAQ. there is alot of good info in there for you. There are some differances but most parts will bolt up.
Old 05-25-2006, 08:14 PM
96capricemgr's Avatar
Might help you to know year for year the Roady, Caprice, Impala, Fleetwood are all the same as eachother and the bottomends are the same as the f-body.
Old 05-25-2006, 08:24 PM
LS1-SEVEN's Avatar
cool I will look in the FAQ. Will the f-body wiring harness and ecu plug into the roadmaster engine.
my94blackz's Avatar
Main difference is heads. I think the rest is univeral. The exaust prolly isnt the same, wiring harness prolly is not
Old 05-25-2006, 08:25 PM
LS1-SEVEN's Avatar
Its a 94
Old 05-25-2006, 08:28 PM
LS1-SEVEN's Avatar
I know the heads are different. I want to swap to aluminum heads.
Old 05-25-2006, 08:33 PM
BlackBirdWs6Zzz's Avatar
I think you should stick with those heads. just have them ported! They can take ALOT more heat then the aluminum!
Old 05-25-2006, 08:56 PM
LS1-SEVEN's Avatar
I wanted to swap to aluminum heads because of the weight. What about aftermarket heads?
Old 05-25-2006, 09:00 PM
the weight ain't THAT much difference. You could take your heads and send them off to loyd elliot to get ported with a matching cam. You would make alot of power with those!
Old 05-25-2006, 09:01 PM
stock for stock neither head is worth swapping to from the other, the irons flow a little more than most of the aluminums, only the best aluminums matching them as cast. For porting though the early lesser flowing aluminums offer the most potential.
There is not a single aftermarket head I would recommend for a stock shortblock porting one of the LT1 castings can work great, for max effort you just want the early aluminums.
The wiring will work.
Old 05-25-2006, 09:02 PM
LS1-SEVEN's Avatar
Do you know how much of a difference? I was thinking 50 pounds.
Old 05-25-2006, 10:21 PM
it is a little under 50lbs more like 47lbs., not saying you were wrong more just verifying you were in the ballpark.
Quick Reply: roadmaster and f-body lt1 engine differences?
