CETA Bumper: A How To
Old 06-02-2006, 05:23 PM
kraaazymike's Avatar
Default CETA Bumper: A How To
As with many other members on here have noticed, there are actaully no write ups on how to CETA. So I dove in today.
What you'll need:
Tools:
Short Phillips Screwdriver
10mm wratchet
needle nose pliers
Materials:
Primer
Color Coat
Masking Tape
Plastic Tarp
300-400 grit sandpaper
1000 grit sandpaper
Step 1: Unbolting the the bumer (optional)
There are 6 bolts and two screws that hold the bumer on along with 4 plastic pull clips on the top and 3 barbed plastic clips underneath the car and 2 more pull clips underneath on either side. You'll have to take out the tail lights and spare tire to access the bolts as well as pull back the carpeting. Some of the bolts are circled in red.
Step 2: Preping the bumper
You need to sand rough the area to be painted with your coarser sandpaper. Not all the way down to the plastic, but just enough to get the surface rough. The idea is to give the primer a surface to stick to.
Now wash the entire bumper with soap and water then dry with a lint free towel. Don't use a chamois because they may leave oils on the bumper which will cause the paint to fisheye.
Then tape off the areas you don't want painted. Give the tape a twice over press down to make sure the tape all sticks. You don't want any paint seeping under the tape at all. Drape the plastic tarp over the bumper to cover the areas you dont want painted from overspray and tape it to the tape you previously laid.
Step 3: Painting the Bumper
Shake the primer well and often. Whether you use a rattle can or HVLP, the techniques are the same. Apply at ~8" away from bumper in even strokes from side to side. Don't ever start or stop a pass directly over the bumper.
Spray -> pass over bumper -> end spray
After the primer has dried fully, you can use the 1000 grit sandpaper to make it smooth. Use a little water with this to prevent the sand paper from clogging.
Apply the color coat the same way as the primer. Except this time the first coat should be barely enough paint to see on the surface. Let this dry so that its tacky enough for the following layers to adhere to.
Since I used a semi-gloss paint, I did not want to use clear. But for those who do, you should apply while the color coat is still tacky. Allow ~15-30 minutes between the layers to keep it from running. If you wnat to color sand, make sure the clear is thick enough to plentifully sand without sanding through.
When you take the tape off, be sure to pull the tape away from the new paint and not straight off the surface. Otherwise the paint may peel.
Color Sanding: (Optional)
To elliminate orange peel, color sanding works wonders but this also takes a little practice and if done wrong you'll need to shoot more layers of clear. You may want to start out with 800 grit wet/dry sandpaper with a sponge behind the sandpaper. If you use your bare hand to hold the paper the sanding tends to come out uneven from the pressure from the tips of your fingers. Have a hose or a bucket of water to keep the work wet at all times. Keep in mind you do not want to sand through the clear coat to the color coat.
When you sand, the clear will become dull and low spots will stay clear. You should sand just enough so that the low spots are sanded away. Repeat this with grit incriments that get higher and higher until you reach about 2000 grit. Then it's time to bring out the buffer.
You'll want to use two compounds to buff out the haze from color sanding. A cutting compound and a polish compound. Keep in mind that the cutting compound cuts away at the paint so use this in moderation. One could do this by hand but it will cut days of work by using a random orbital buffer or analagous. Also keep in mind that any buffer you use may burn through the paint if kept in a spot for too long. Buff the painted area with cutting compound until most of the haze is out equally throughout. Then use a polish compound until the shine in the clear comes through. Just remember that through all this, you should not sand all the way through the clear, or youll have to respray the entire clear all over again.
Step 4: Reinstall. Replace bumper with all clips and screws. Replace tail lights with filler panel and replace interior.
Step 5: Enjoy!
Before:
After:
Semi-gloss:
Gloss:
c/o: GotV-8
Matte Black:
c/o: 5550racing
Old 06-02-2006, 05:28 PM
FBodyPerformer's Avatar
Thanks for the write-up! Ive looked for one but never found it. Now Im just paying someone to repaint my entire bumper and do the CETA. What color are you suppose to use for the black though? Flat, semi or gloss? Im thinking semi would look best.
Old 06-02-2006, 05:32 PM
I was on the fence between which finish too. Then I just decided to go half way between flat and gloss and went with semi-gloss Best of both worlds?
Old 06-02-2006, 05:43 PM
crazymofo1986's Avatar
i went flat black. and to save alot of time you really dont need to take off the bumper
Old 06-02-2006, 05:46 PM
And just incase anyone else missed it.
Old 06-02-2006, 05:47 PM
STRETCH'S T/A's Avatar
nice write up with pics. i went with gloss, i was going to remove the bumper but i just put up on jackstands and that was high enough to get to the underneath portion.
Old 06-02-2006, 05:52 PM
my bad
Old 06-02-2006, 06:15 PM
nhra-trans-am's Avatar
Awesome, want to do mine?
Old 06-03-2006, 12:22 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Taking the bumper off is kinda over kill, just tape/prep...
Old 06-03-2006, 01:48 AM
phantomzer0's Avatar
There is no such thing as overkill when it comes to paint and your ******' ride! As far as i see it, every step of precaution will only save a potential headache in the future.
Old 06-03-2006, 08:27 AM
Sgt. Spuds's Avatar
When I posted that I hadn't read the thread, I just read it today and seen you said optional.
Old 06-03-2006, 08:46 AM
Between you and Crazymofo'86 its all good
Old 06-03-2006, 08:55 AM
Sgt. Spuds's Avatar
Also, I didn't see any clearing steps in the how too.
Old 06-03-2006, 08:57 AM
I didnt want clear. But I suppose I could add that for those who do.
Old 06-03-2006, 09:03 AM
casey02ws6's Avatar
Nice write up and awesome result. I am kicking around doing it myself. It is not whether I will do it or not - it's going to happen! I am just not sure whether to do it myself. I have done everything else to my car but I had drawn the line at body or paint. Hmmm.....
Old 06-03-2006, 09:29 AM
Jimmyd02's Avatar
I'm in the same situation, I definitely want it done but I don't really trust myself with it. Seeing this post helped me decide on semi-gloss finish, thanks!
Old 06-03-2006, 09:59 AM
Scotty-Z's Avatar
I think this needs to be a sticky.
And I can honestly say that if I had a TA and was going to do this (which I most definitely would!), I'd take the bumper off as well. Every precaution helps.
Great job on it. Looks amazing! I'm a fan of black on pewter too.
Oh, by the way, your driveway and surrounding floral area/trees look great as well!
Old 06-03-2006, 10:17 AM
Sgt. Spuds's Avatar
Painting isn't really all that hard of a task. As long as you think things out, use quality tape/paint, take your time, and PREP, you will do fine, whats the worse that could happen? If you screw it up, and decide aginst trying it again, then you just have to pay someone that knows whats up to paint it, which you would have done anyways, so why not try it yourself first and save some coin??
Old 06-03-2006, 10:35 AM
99Hawk262's Avatar
I did my buddies TA in my driveway. I paint aircraft for a living and I'm with Sgt. Spuds.....PREP is everything. It took a total of about one hour to do the whole thing and it turned out great. We used flat black and it dried very quickly. We didn't wash it or anything for a week or so, but a year later it still looks great. Very simple mod and I would tell anybody to do it themselves. Just take your time.
Old 06-03-2006, 07:11 PM
Thanks Scotty-Z
Quick Reply: CETA Bumper: A How To
