Thread pitch and size of the F-body AC pressor sensor
I am in the final stages of getting the AC in my car to work using the LS1 PCM. One piece I need to sort out is the size and pitch of the stock 98 Camaro LS1 AC pressor Sensor. It has female threads and it does fit (roughly) on an old-style schrader high pressure port, but it needs an o-ring and the threads are not quite right. I also need to know what type of port the Chevy part is called and what other cars or trucks might have one.
It is not a standard on-off switch or a "trinary" switch that also sends a signal to a fan - it is a pressure sensor that the PCM uses to know if the pressure is too low or too high. The AC Delco part number for the sensor is: 15-5742 and the GM part number is 22664328
I have called all of the Hot Rod AC places and no one seems to know this.
Thanks in advance for any help.
