K-member, A-arms, front AFCO's with springs
Old Jun 21, 2006 | 03:15 PM
y2khawk's Avatar
Default K-member, A-arms, front AFCO's with springs
Complete front suspension, wheels, tires, brakes, and manual rack for sale. Items are priced individually, take the package for $3600 + shipping. Take it all, and I'll toss in the stock upper a-arms/mounts with new ball joints and poly bushings.
Bolt it, a little brake line work, quick alignment, and you've got a race ready setup
pair of Weld one-piece Alumastar 2.0's - 15x3.5 2.25" BS with used ET fronts mounted, set of 10 lugnuts for 1/2-20 studs - SOLD
Strange heavy duty drag brakes, complete with modified factory spindle (trimmed factory caliper ears, drilled for manual rack bump steer kit, and powder coated black), Strange aluminum hub, 1/2 studs, braided brake lines (-3 AN on both sides) - SOLD
Double adjustable AFCO front shocks, complete with HAL/QA1 300 front springs, aluminum spring spacers, torrington bearings for easy spring adjustment, modified stock uppper spring seat for the upper shock adjustment - SOLD
price lowered
Madman manual rack kit with steering shaft and bump steer kit - SOLD
will be repainted before shipping
http://www.stenodracing.com/forsale/new/DSC04478.JPG
PA mild steel k-member WITHOUT motor mount provisions, powder coated black. Can add the mount locations back for an added price. - $300
PA chromemoly A-Arms, coated black. New teflon insert rod ends last time the car ran (12 passes since new). - SOLD
Will get a full "bath" before shipping.
http://www.stenodracing.com/forsale/new/DSC04475.JPG
http://www.stenodracing.com/forsale/new/DSC04476.JPG
http://www.stenodracing.com/forsale/new/DSC04477.JPG
Old Jun 22, 2006 | 08:59 AM
Carbed4thGen's Avatar
How low are you willing to go on the wheels? I can get them brand new for under $800. Will you sell JUST the wheels? Let me know
Old Jun 22, 2006 | 10:07 AM
y2khawk's Avatar
PM sent
Old Jun 22, 2006 | 04:02 PM
cablebandit's Avatar
can you use the brakes with power steering? If so, what needs to be modded?
Old Jun 22, 2006 | 10:36 PM
y2khawk's Avatar
Power steering, as in the stock rack? The version of the bumb steer kit on the car still allow the use of factory tapered ball-joint type tie rod ends. I just put a stock rack on to confirm, and the joints tighten up just like they should.
so yes
Old Jun 23, 2006 | 01:12 AM
red90cobra's Avatar
How are you going to put the mounts back? and how much for that?
Old Jun 24, 2006 | 02:03 AM
DMH Fabrication's Avatar
pm me about the wheels... whats bottom dollar on them?
Old Jun 24, 2006 | 11:35 AM
fash00's Avatar
Pm me bottom dollar on the Strange heavy duty drag brakes, complete with modified factory spindle (trimmed factory caliper ears, drilled for manual rack bump steer kit, and powder coated black), Strange aluminum hub, 1/2 studs, braided brake lines (-3 AN on both sides) - $800
Old Jun 28, 2006 | 12:00 PM
y2khawk's Avatar
Old Jun 29, 2006 | 03:34 PM
y2khawk's Avatar
Woot
Update on package price.
Some pics of the brakes..
http://stenodracing.com/forsale/brakes/DSC04356.JPG
http://stenodracing.com/forsale/brakes/DSC04357.JPG
http://stenodracing.com/forsale/brakes/DSC04358.JPG
http://stenodracing.com/forsale/brakes/DSC04359.JPG
http://stenodracing.com/forsale/brakes/DSC04360.JPG
http://stenodracing.com/forsale/brakes/DSC04363.JPG
http://stenodracing.com/forsale/brakes/DSC04364.JPG
http://stenodracing.com/forsale/brakes/DSC04365.JPG
http://stenodracing.com/forsale/brakes/DSC04366.JPG
http://stenodracing.com/forsale/brakes/DSC04367.JPG
http://stenodracing.com/forsale/brakes/DSC04368.JPG
Old Jul 1, 2006 | 12:03 PM
y2khawk's Avatar
bump
Old Jul 2, 2006 | 01:05 PM
FormulaFire's Avatar
How would those shocks/springs be a street car?
Old Jul 2, 2006 | 08:50 PM
Hot Copper Z's Avatar
Is that upper and lower a-arms?
Old Jul 4, 2006 | 03:33 AM
y2khawk's Avatar
shocks and springs would be fine on the street. Stiffen up the shocks for street duty, adjust as needed for the track.
Lower's are tubular, uppers were still stock but with poly bushings.
Old Jul 5, 2006 | 02:49 PM
y2khawk's Avatar
reasonable offers?
beuler, beuler, beuler??
Old Jul 5, 2006 | 03:11 PM
phoenix's Avatar
will these brakes fit with a 15'prostar?
Old Jul 5, 2006 | 03:16 PM
y2khawk's Avatar
Yep. I ran them with large backspace alumastars and they have less room that the prostars.
Old Jul 6, 2006 | 02:36 PM
jshiver's Avatar
Would you please get me some pics of the a-arms too? Thanks
Old Jul 6, 2006 | 05:16 PM
y2khawk's Avatar
I'll get them tonight.
Updated the remaining items....
Old Jul 9, 2006 | 06:49 AM
y2khawk's Avatar
added some pic's of the other stuff. Rack needs a coat of paint, and the k-member needs a bath. But you get the idea.
