Who runs boost with the LG5X3 cam?
I currently have LG5X3,FAST90/90,Kooks/Patriot stg2 66cc's. I know that my motor will only last so long with a stock bottom end. So I figured I'd just put a Vortech S-Trim with 6.5lbs of boost on it till it goes. Does anyone have similar experience and how much boost did you run?
Al
Al
Originally Posted by Frost
Are all the g5x3's ground on a 114LSA? My buddy has a freak 'hawk that put down 633RW with QTPs, electric water pump, that G5 cam with a 114LSA, and a P1sc on a stock longblock... so I don't see that the cam will be a problem...
Originally Posted by FormulaFire
633 with a P1SC is impressive. Esp stock longblock. Damn
Yeah he's got the golden car though Here is some video from last season of the tech race at MIR with him running mid-10s in the blistering heat of the day on stock 10 bolt and 6 speed which, by the way, lasted him a full season and was changed out unbroken. You can see how well that G5X3 worked with his last setup
The video is 29MB:
http://frozenwaste.com/Frost/RPM/ad_mir_big.wmv
Here's the dyno board from the local shop. You may recognize the other top 2 as well
How much psi was that red Firehawk running? Very sweet vid.
I've got a cam in the 230 range and my Incons are almost done. The idle sound (chop) was similar to mine N/A... I've got a 236/236 112 LSA.
Thanks ~Joshua
Thanks ~Joshua
Senior Member
No, mine was a 112.
Thanks ~Joshua
Thanks ~Joshua
That's a monster cam you have there I'd imagine they'd sound pretty similar.
Here's a pic of his car from the day of the video that I've always liked...
Good times for a 6-spd and that wheel/tire combo, I know I wouldn't be able to drive it so well... Here's a short video of what I believe was his best pass last year: http://www.frozenwaste.com/Frost/RPM/adam1048_lrg.avi
