Speed density tune????
Old 07-05-2006, 11:48 AM
JerikSS's Avatar
Default Speed density tune????
I want to be able to run more than one boost setting on my set up. I have done research and it seems that SD tune would be the way to go. What do I need to run an SD tune?? How hard is it to maintain the tune? How much more does it cost over the normal dynotune? How will it do on my daily driver??
Old 07-05-2006, 11:54 AM
LS1Tech Sponsor
Superman09's Avatar
I believe from what i've gathered you need to ditch your MAF and replace your MAP with a 2 bar or 3 bar MAP. 2 bar is boost levels from 1-15 psi i believe and 3 bar is 1-30 PSI. i may be wrong on these numbers but am pretty sure all you need to do is ditch the MAF and swap your stock 1 bar MAP for a 2 bar or 3 bar MAP. The MAP is located on the back of the intake manifold FYI
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 07-05-2006, 11:57 AM
markp03's Avatar
you need to do what was said above and then obviously get it tuned....i think it would be the best to tune it yourself so you can make changes based on the weather, thats what i will be doing.
Old 07-05-2006, 12:01 PM
LTLHOMER's Avatar
I don't run the stock computer, but speed density is speed density and I've not yet touched my tune and I've run it at all kinds of different boost levels. I log my afr and it's been fine so far.
You shouldn't have to constantly tune your car unless you're looking to get every last millisecond out of the car.
Old 07-05-2006, 12:13 PM
JerikSS's Avatar
What would I need to get my sd tune started? Do you remove the maf completely or do I just unplug it?? Do I remove any other sensor besides the maf? Where can I get the 3 bar map sensor?
Old 07-05-2006, 12:24 PM
LTLHOMER's Avatar
Can get 3-bar map from GM dealer or something similar...dunno the p/n off-hand but you can do a search and find it quickly.
The other questions I do not know...you could probably leave the maf if you wanted but you'd prolly make a few buck by selling it and then it would be out of the way and not an eyesore.
Old 07-05-2006, 01:19 PM
JMBLOWNWS6's Avatar
Im running a 2 bar setup with HPT custom OS.
I used the 2 bar map from a GM. Just had to cut off a mounting tab on the sensor and it was plug and play.
GM PN# 12223861 3bar MAP
GM PN# 16040609 2bar MAP
GM PN# 16137039 1bar MAP
GM PN# 15305891 - pigtail harness
Old 07-05-2006, 01:34 PM
longrange4u's Avatar
What software are you guys using to monitor and adjust the tune on your SD?
Old 07-05-2006, 01:49 PM
MECHAM's Avatar
hp tuners..
Old 07-05-2006, 02:08 PM
frcefed98's Avatar
GM PN 12580698
Is the 2 bar Sensor
Old 07-05-2006, 02:13 PM
JMBLOWNWS6's Avatar
Originally Posted by frcefed98
GM PN 12580698
Is the 2 bar Sensor
Hmm I used the part number I listed and and it referenced to the cobalt ss
Old 07-05-2006, 02:14 PM
JMBLOWNWS6's Avatar
I had to change the scanner to 2 bar. I was when I couldnt monitor when I went into boost. Opps Im using HP tuners.
Old 07-05-2006, 10:02 PM
Ok so does this mean that if you want to run more than 15lbs you need to go with a 3-Bar tune? How hard is it to tune with an HP tuners?
Old 07-06-2006, 12:18 AM
markp03's Avatar
yup a 3 bar will get you to 30#'s of boost. from what i hear SD is easyer to tune then with the maf...
Old 07-06-2006, 12:40 AM
FormulaFire's Avatar
So what do us 98 guys do if we want to run more than 15#? I know HPtuners only came out with a 2 bar for 98s recently. And I def plan on running More than 14.7# of boost..
Old 07-06-2006, 06:25 AM
JMBLOWNWS6's Avatar
I had to build my VE table from scratch. Actually its still being built. I wouldnt say its easy at all.
Old 07-06-2006, 08:27 AM
Ok so if I purchase a 3 Bar MAP... and I purchase the basic licence of HP Tuners (8 Credits right?) then I can tune my car with a 2 bar or 3 bar if I choose? How difficult is it truly to tune your own car? If its easy why isnt everyone doing it? Is there somewhere good to learn more about tuning a Speed Density tune?
For those of us who really dont know... can someone do a detailed explanition of why a SD tune is so much more valuble than the standard MAF tune for us FI guys?
Thanks!!
Old 07-06-2006, 10:31 AM
I'm in the same boat longrange. I really want to start learning how to do my own tuning. But I think I'm going to get a Big Stuff 3 and go that route instead of HPTuners.
Old 07-06-2006, 01:51 PM
frcefed98's Avatar
The PN I listed has been the PN thats been used for sometime when going two bar with the GM PCM on a LS1 F body. I've been running it in the car since feb.
either way if both work its all good right?
J
Old 07-06-2006, 02:20 PM
KyleW93z's Avatar
Speed density is not the easiest thing to do by any means, and ditch the MAF, its just a airflow restriction. Im using TTS Datamaster and TunerPro, but im on a lowly 93.
