Alternator, A/C compressor, MAf Translator
Up for grabs:
A/C compressor w/ A/C lines off of a 2005 6.0 LQ9 motor. Engine had less than 4,xxx miles before removal. This SHOULD be Interchangeable with the F bodies, if you change the bracket. Not to sure or positive on that.
$100
150 AMP Alternator. Also off of a 2005 6.0 LQ9 motor. Engine had less than 4,xxx miles before removal. I know this DOES FIT the F body bracket since I personally tried it on my bodies old motor he had out of the car.
$100
The Famous Bob Bailey MAF Translator. It is revision 4.0. I have personaly been in contact with bob bailey, and he himself has told me that the only difference between version 4.0 and the newer one, are changes for the TURBO BUICK MAF. NOTHING ELSE. So if your planning to use this on an LT1 or LS1 your fine with this one.
Only $50******SOLD************
$100
$100
