lots of parts of sale in mansfield
i'm about 30 mi south of dallas
i've parted out several cars and have lots of parts lying around here's a list of what i found so far but there are many more to come
complete trans am steering column with air bag and steering wheel with volumn controls- $150
complete 98 camaro steering column with air bag and steering wheel- $150
93-96 camaro gauge cluster bezel in ebony- $20
charcole sail panels- $40 for the pair
98-02 A/C control panel- $20
98-02 headlight control panel- $20
98 camaro z28 stock injectors with only 42k miles- $50
hatch weather strip (does not leak)-$10
cig lighters in gray and black- $5 each
Vats bypass module- $15
camaro z28 3rd brake light- $10
hatch release button- $5
interior dome lights in charcole and tan- $10 each
LS1 camaro tail lights (passnger one has a small crack in it but you have to look for it)- $80 for the pair
complete camaro hatch in red- $60
camaro spoiler with 3rd brake light in white- $25
c-pillars in ebony- $10
ls1 rockers with only 42k miles-$80
LS1 rocker guides-$20
98 LS1 fuel rail assembly- $50
complete set or tan leather seats out of a 98 camaro (drivers seat had oil spilt on it and the rear seat back has a 2-in rip in it)-$100 for the set
drivers camaro doors one is red the other is white- $80 each
passenger trans am door in a non-factory metalic silver color- $80
red camaro z28 rear bumper with a few chips in the paint-$25
red rear beager panel with z28- $25
trans am rear bumper in a non-factory metalic silver color- $60
323 3-channel stock 10 bolt rearend with 76k miles- $250
ls1 front brake upgrade (includes ls1 calipers, spindels, and rotors) $200
ls1 k-member-$60
Lt1 k-member- $50
ls1 fuel sending unit with stock fuel pump- $80
lt1 fuel sending unit with stock fuel pump- $80
lt1 fuel sending unit with out fuel pump- $60
lt1 fuel tank- $10
lt1 3-channel abs module- $30
lt1 4-channel abs module- $40
ls1 3-channel abs module- $50
ls1 steering rack and pinion- $40
ac condinser- $20
LT1 non-ram air firebird/trans am hood in a non-factory metalic silver color- $40
washer fluid resivor with pump- $10
brake booster- $20
LS1 PCM holder bracket- $10
LT1 starter with 76k miles- $60
LT1 motor mounts- $40
LS1 motor mounts-$50
LS1 front strut assemblies with only 42k miles- $80 pair
LS1 lower a-arms- $30 pair
LS1 upper a-arms- $10 pair
LT1 lower a-arms- $20 pair
LT1 upper a-arms- $10 pair
98 LS1 MAF- $40
LT1 front brake calipers- $40 pair
horn assembly- $20
drivers side tan sunvisor in perfect condition- $15
tan hard top headliner in perfect condition- $40
M6 pedal assembly out of a 98 camaro with sensors- $60
complete set of tan seatbelts- $40
fuel lines for lt1 and ls1- make offer
93-96 camaro glove box in ebony- $20
LT1 power steering resivor with cap- $15
LS1 e-brake cables- $30 set
e-brake handle- $25
drivers air bag out of a 96 trans am (i think it will work on any 95-97 firebird or trans am)- $50
rear view mirror- $10
factory amp out of a 97 trans am- $40
several front and rear sway bars out of a 96 camaro z28, 97 trans am, and 98 camaro z28- $5 each
global west ADJ PHB- $100
tan leather interior door panels (the're kinda dirty)- $30 for the pair
that's all i can think of right now but i'm sure i'll add stuff a later
all prices are OBO and plus shipping if needed
i would prefer local pickup
check my feedback if you feel the need to verify i'm an honest person
thanks
robbie
ls1 k-member-$60
Lt1 k-member- $50
lt1 fuel tank- $10
ac condinser- $20
brake booster- $20
98 LS1 MAF- $40
horn assembly- $20
e-brake handle- $25
thanks
robbie
James
rack and pinion is in perfect condition. PM sent
thanks
robbie
thanks
robbie
James
Originally Posted by MESS
You still have those 3.42 gears laying around in your garage?????
thanks
robbie
