O2 simulators for less than $10.00
Old 07-16-2006, 05:23 PM
bobodog's Avatar
Default 02 simulators for less than $10.00
yep,thats right! less than $10.00. all you need to do is go to local parts store and buy 2 sets of sparkplug antifowelers. get a 9/16 drill bit and drill out one sparkplug antifoweler so the senser fits. screw it onto the senser then screw the other sparkplug antifoweler into the exhaust then connect them by screwing them together. thats it! then do the same thing to the other side. its simple as ****. I did it 2 months ago after i hollowed out my cats and no SES light still. it saved my *** $180 at summit for their 02 simulaters.
Old 07-16-2006, 05:43 PM
2KThunder's Avatar
Yeah id heard of this before too. Here is a link to a more detailed explanation:
http://forums.evolutionm.net/showpos...17&postcount=2
The antifoulers basically just move the 02 back so its not seeing as much of the exhaust gas.
Old 07-16-2006, 06:07 PM
((((((Administrator))))))
CRAGER's Avatar
Originally Posted by bobodog
....it saved my *** $180 at summit for their 02 simulaters.
http://www.thunderracing.com/catalog...vid=3&pcid=156
125-104035 O2 Simulator (Single) - 1996-up V8 F-body/Corvette (2 required) - OFF ROAD USE ONLY $44.99
x 2 = $89.98
I don't know why Summit would be that high, $90 is alot more then $10, but then again getting a custom tune is the best way to go.
Peace,
Craig.
Old 08-05-2006, 01:57 PM
yellowgtogirl's Avatar
We just hollowed out the cats on our 05 ls2 gto and this worked awesome!! Thanks!!!
No ses light either!!!!
Old 08-05-2006, 05:26 PM
Fibbado's Avatar
Yeah i did this in order to pass EMissions.. worked great.. highly recomended
Old 08-06-2006, 01:02 AM
RrCoX22's Avatar
is there a more detailed write-up on this... that link previously posted doesn't work
Old 08-06-2006, 01:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Tune on mine worked just fine! I have a spare set if anyone needs to have some.
Old 08-06-2006, 01:08 AM
2002_Z28_Six_Speed's Avatar
Link doesn't work. Anyone have pics of this anti-fowler?
RrCoX22's Avatar
would have took them but i'm looking for something for just about a week as i'll be running open headers and then getting them tuned out
Old 08-06-2006, 01:10 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Google?
Old 08-06-2006, 01:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Open headers? In California? Isn't that like going to church with a beer in your hand?
Old 08-06-2006, 01:13 AM
RrCoX22's Avatar
might as well post a flag with "Pull My *** Over"
Old 08-06-2006, 01:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Old 08-06-2006, 02:22 AM
2KThunder's Avatar
Which link doesnt work? The link I posted works fine here. Its not that difficult really:
You put that inbetween the O2 and the bung, and it removes the O2 from the exhaust stream, giving the illusion the air is cleaner.
Old 08-06-2006, 09:32 AM
Starz T/A 17's Avatar
I wish I could do that with my LT's but I dont have 02 bungs on my Y pipe
Old 08-06-2006, 11:24 AM
DomesticLS1's Avatar
got a quick question. So there is 2 in a package so 1 for each side? The link above shows the 2 screwed in to each other and then the o2 in that? JW im about to go buy some and need to know how many packages I need to buy. Thanks
Old 08-06-2006, 12:39 PM
2KThunder's Avatar
Yep, you need 2 sets.
Old 08-06-2006, 01:00 PM
one2run's Avatar
i have hooker long tunes with the bungs on the outside of the merge collector. i was so damn excited when i saw this fix. went out to the car and realized i would not be able to get one of them anti-fowlers in let alone 2 of them... i would have to dent or cut at the sub frame...
i will try to get the one up there, but if it doesn't fix the SES light and swithching code, i am only out 8 bucks and some time...
Old 08-06-2006, 01:45 PM
one2run's Avatar
whoops, just realized this was for the rear 02's. hmmm... i wonder if it will work for the fronts...
Old 08-06-2006, 01:54 PM
2KThunder's Avatar
Your front O2s are needed by the PCM
Quick Reply: O2 simulators for less than $10.00
