Florida Members Fun, sun and LS1's
10 Bolt from 99 t/a
Old Jul 17, 2006 | 09:50 AM
ls1mongrel's Avatar
Default 10 Bolt from 99 t/a
I just bought a 12 bolt, and wanna sell this , car has 40k on it and about 20 passes on motor, never sprayed with this rear, its works perfect, whines a little on decel, always has, had ratech deluxe install kit, with gear install, had everything check when gears were installed , has richmond 3.73 gears in it, t/a girdle, welded tubes, its 4 channel , its complete with backing plates but not any brakes or calipers. Asking $500 complete, $400 with no backing plates and $300 with no backing plates and no girdle ! Ready for pickup !
Old Jul 20, 2006 | 06:30 PM
five0killr's Avatar
whats welded tubes, and im kind of oblivious to what a 4 channel is, so when you say minus the 4 channel, whats that mean?
Old Jul 20, 2006 | 06:50 PM
ls1mongrel's Avatar
Welded tubes just helps strengthen the rear a bight, the axle tubes are press into tjhe center housing, I had them welded to help a bit, and 4 channel is for abs/tcs rearend
Old Jul 24, 2006 | 05:48 AM
ls1mongrel's Avatar
Bump!
ls1mongrel's Avatar
Bump !
Old Jul 25, 2006 | 02:29 PM
ls1mongrel's Avatar
Bump !
Old Jul 25, 2006 | 03:48 PM
Predator T/A's Avatar
you may want to consider dropping the price a little 500 is bit much for 10 bolt........and if it is whining on decel sounds like there may be a pinion bearing problem or the backlash wasnt set right
Old Aug 2, 2006 | 08:43 AM
ls1mongrel's Avatar
Bump !
Old Aug 2, 2006 | 03:55 PM
presto_z's Avatar
how loud is the whine.... is it cause of the gear swap??? richmonds are naturally louder then stock...... pm me with more info
Old Aug 18, 2006 | 11:37 AM
ls1mongrel's Avatar
Bump !
Old Aug 18, 2006 | 09:19 PM
396D1SS's Avatar
wanna sell just the cover?
Old Aug 22, 2006 | 09:51 AM
ls1mongrel's Avatar
If i can find someone to buy the rest of it I will, ILl let ya know !
