JE 408 Blower Pistons
JE Part No. 2211176 New in Box set of 8. These are for 4.030 bore; 4.000 stroke; 6.125 rod; 29cc inverted dome. Comes with pins and rings. Sell for $500
JE says the -29cc dish piston #221176 will have a 9.0 to 1 static compression ratio with 66cc chambers or a 8.6 to 1 ratio with 72cc heads. These are calculated with a .042 gasket. These were part of an Eagle rotating assembly for blower or turbo use. I am going unblown and need the eqivalent flat top.
I have a set of wiseco pistons for a 408. -12 cc, with a 62cc chamber and .042 gasket would be almost 11.1 comp ratio. Im in dallas too if you wanted to work a trade.
just an idea.
Ed
firebird455@gmail.com
just an idea.
Ed
