Giant list...Some Performance, Stock stuff too
My Stuff
added...
sub box for 2 12's for hatch area recieved from a friend...asking 150...
hooker ORY 3 inch inlets with 3 bolt flanges welded...into a single 3 inch with a flange welded, mouting to this is a cutout welded to a stock lt1 catback...(this car was whisper quiet with it closed...and when you opened it it was full race baby! this is on my car with hooker LT cc306 stall and gears and my car runs 7.80s easily
passenger airbag intact and perfect
trickflow elbow never installed...paid 89 from jegs willing to let it go for 79(you dont pay shipping) comes with clamps and rubber
optima yellow top...with top and side posts, this is in the back of my car, i have enough 0 gauge wire to run front to back of the car, and another 2 feet or so for a ground this also has gold connectors at the end of it... (wire costs 70 bux, connectors 10) will sell for 150...might consider trade for stock battery...or part these
white leather rear seats/front seats with z28 embroidered in head rest...wanting to sell as a set or trade for racing seats...rears need tlc look decent...475
rear seatbelts and brackets dark grey...15
i have 3 motor mounts...both drivers side mounts and passenger side bracket
96-97 exhaust manifolds....also have a driver side cat...
crank for lt1...15
3 main cap bolts...
stock lt1 cam...25 65k
stock lt1 cam gear new...10
stock lt1 cam gear new minus the waterpump teeth are chipped...
stock lt1 valvetrain (spring reatianers locks studs valves)... 65k on them
2 complete a/c systems with one compressor...condensor dryer lines sensors included...
heater, box inside and out with good core available...pm for details
one perfect drivers side ttop shade...
6 speed shifter...short throw now" its been cut about inch and half, pm me for pics...15obo
map sensors 1 brand new 1 low miles ...5
one good 1 wire front o2 sensor ....
2 stock air pumps...
2 stock mufflers
2 stock z28 tips
set of lt1 front brake pads almost new...15
front swaybar with endlinks
one passenger fuel rail
one fuel line bracket(by the fpr)
fuel air line that goes to under the drivers seat connects with line under the t/b
stock plug wires
spark plug shields
rear main seal cover gasket
couple misc gaskets
steering linkage cover
stock jack and spare tire
stock bose sub
bose door amps
3.23 gear set
wheels tires
2 bfg drag radials with 9% left...
2 mint salad shooters no tires
2 mint salad shooters about 10% left
2 salad shooters bald tires
2 salad shooters 20%
2 chrome stock t/a abs wheels with tires(have nipples) about 15% left
2 kumho esta supra tires, life?
any tires or wheels can be seperated...
http://s21.photobucket.com/albums/b2...8/Car%20Parts/
Parts needed..
2 bullet mufflers...prefer magnaflow or dynomax..
i need a passenger mirror/shell power...preferrably black
some 275 40 17 with some decdent tread left
plastic line that goes on both sides on the intake manifold under the throttle body to the fuel lines...
everything is make offer...i need this stuff gone
daniel
added...
crank for lt1...15
3 main cap bolts...
2 stock mufflers
2 stock z28 tips
stock plug wires
spark plug shields
couple misc gaskets
stock bose sub
bose door amps
3.23 gear set
wheels tires
Parts needed..
daniel
i dont have a pic f the short stick bc my friend just put it on his car...but it still mine...its a stock stick with the arch cut out...so its about 2 inches shorter...
the finish on the elbox i think is smoothe not polished..and not black...
check it out today...elbow is spoken for 2 salad shooters...and the 2 bfg drag radials...also had alot of hits on the compressor but no for sures yet...
check out the link
check out the link
if you mean timing cover no...i ahve the seals for opti the wp shaft ect that go in the timing cover...
abs wheels might be spoken for, if no i wanted 75 for the 2 shipping prolly around 35 or so
