lots of parts form a 98 camaro z28, 97 trans am, 96 camaro z28, and a 95 formula
i have parted out several cars and still have lots of parts left over
98 camaro z28 M6 with 42k miles
radio bezel-$40
HVAC controls-$25
headlight controls-$20
stock injectors (8)-$40
door handel bezels-$10 set
Drivers door in red complete with window-$100
z28 hatch in red with spoiler-$50
tan leather seats (not in very good condition)-$100 for the set front and back
tail lights (drivers one has a 2 in crack in the yellow lense but it's not very noticable)-$75 for the set
e-brake handel assembly-$25
rear tan seat belts-$30
hatch struts-$20
tail light wireing harness-$20
washer fluid resivor with motor-$10
dash in ebony-$150
passenger air bag-$40
steering column with airbag and steering wheel-$150 or $50 for the airbag and $100 for the wheel and column
front shock/strut assemblies- $60 pair
pair of LS1 z28 crome rims with centercaps and good tires-$60
pair of stock axles-$50
hatch weather strip (does not leak)-$10
shock sensor-$7
air bag sensor-$25
red lenses in rear bumper-$10 pair
stock LCA's-$15 pair
rear bumper support-$20
stock torque arm-$20
stock amp-$40
fuel rail assembly-$50
stock exhaust from the manfolds to the i-pipe includes manfolds, cats, O2 sensors, y-pipe, and i-pipe to the rear end-$40 picked up
15 stock lifters and 15 stock pushrods-make offer
tan hardtop headliner (looks new)-$40
steering coupler-$10
brake master cylinder with resivor-$20
brake booster-$15
heater lines-$20
95 formula M6
triangle interior mirror pieces-$10 pair
t-top holders in the trunk-$30 set
brake booster-$10
heater lines-$20
gray cloth seats-$120 for the set front and back
gray cloth door panels-$60 pair
headlight control panel-$20
HVAC control panel-$25
stock 10 bolt with 342's complete-$250
charcoal dash-$150
passenger airbag-$40
drivers t-top-$160
a-pillars-$50 pair
b-pillars-$10 pair
t-top weather strip-$40
formula hatch in silver-$50
mirrors in silver-$30 each
rear bumper in silver-$40
gray front seatbelts-$40
hood strut assemblies-$20
front shock/strut assemblies-$60 pair
gray interior dome light-$10
hatch weatherstrip (does not leak)-$10
idler pulley-$20
stock amp-$25
M6 rubber shift boot-$20
rear view mirror-$20
drivers door (needs new window motor)-$75
tail light center piece-$30
complete exhaust includes hooker shorties, a hooker y-pipe, a high flow cat, a flowmaster muffler, a cutout, and dual tips. i pulled it with out cutting it so you could install in without a welder-$400 picked up
96 camaro z28 M6
defrost switch-$10
white z28 spoiler with 3rd brake light-$25
gauge bezel in ebony-$20
drivers door in white-$100
horn assembly with wireing harness-$20
front rotors in lightly used condition-$20 pair
motor mounts complete set-$40
hood hinges-$20 pair
PCM holder-$10
front brake calipers-$30 pair
stock fuel pump-$20
brake master cylinder and resivor-$20
brake booster-$10
power steering fluid resivor-$20
k-member-$50
stock lower a-arms-$20 pair
97 trans am a4
fog light switch-$15
non ram air stock hood in an after market metalic silver color-$40 picked up
trans am rear bumper in an after market metalic silver color-$80
hood struts-$20 set
stock amp with mounting bracket-$40
a-4 steel dirve shaft-$40
complete 323 10 bolt rear-$250
passenger a-pillar-$10
other parts
hatch releast buttons-$5 each
cig lighters in gray and ebony-$5 each
10# edlebrock N2O bottle with pressure gauge-$100
ball milled LT1 front rotors in lightly used condition (less then 500 miles)-$40 pair
Lt1 under drive pulley with belt-$30
set of k-member bolts (6 bolts)-$10
ENKEI 17 in 3 piece 5-star wheels. the rears are wrapped in Nitto 555 extreme ZR's 285/40 ZR17 and the fronts are wrapped in BFG's G-force T/A KDW's 275/40 zr17. i'll take $900 for the set they are very sharpe looking rims. get me an e-mail of you would like pics
18 in gun metal 6-spoke rims in need of tires-$200 for all 4
f-body drivers window-$40
4-bolt main 350 out of a 77 GMC jimmy. it was running when pulled but it has been sitting for just over 2 years. $250 picked up
all prices are OBO and plus shipping
if you need anything else i probly have it so send me a pm.
my paypal is misdswimmer@hotmail.com
i'm located in mansfield tx 76063
thanks
robbie
radio bezel-$40
HVAC controls-$25
hatch struts-$20
dash in ebony-$150
shock sensor-$7
air bag sensor-$25
stock amp-$40
brake booster-$15
heater lines-$20
95 formula M6
brake booster-$10
heater lines-$20
charcoal dash-$150
drivers t-top-$160
a-pillars-$50 pair
b-pillars-$10 pair
idler pulley-$20
stock amp-$25
96 camaro z28 M6
defrost switch-$10
PCM holder-$10
stock fuel pump-$20
brake booster-$10
k-member-$50
97 trans am a4
hood struts-$20 set
other parts
thanks
robbie
Do you still have these?
this the part in which the window controls are mounted on right?
If those are the bezels you are refering to and i will take them.
Where in Texas are you?
drop me a line and let me know how do u want payment and stuff.
