one more S13/LS1 swap in the works
Old 08-26-2006, 12:34 AM
icantdrift's Avatar
Default one more S13/LS1 swap in the works
finally made some progress with the car tonight. did a good bit more beating on the trans tunnel and got the motor sitting where i want it to be. i'll likely have to pull it back out after i build the mounts to clear things a litte more but i'm happy with the positioning. the bottom of the pan is pretty much flush with the base of the crossmember, the back of the heads is about 1.5" forward of the firewall, and suprisingly enough, the stock hood will fit once i cut one rib out of it .
i'll get some more detailed pics tomorrow of the pan positioning and clearance, just wanted to jump on the bandwagon
Old 08-26-2006, 09:16 AM
Ted J's Avatar
Looking good man! You are giving me hope that maybe the stock hood will fit at first since I was thinking that it might not. Guess I'll have to test fit it later to find out for myself.
Old 08-26-2006, 09:17 AM
owen v8litew8's Avatar
oh yeaaaaaaaaah that LS1 sits nice in there!
nice setup, what are the overall project plans for the car?
Old 08-26-2006, 09:24 AM
Ted J's Avatar
I was just thinking, is the LS6 intake actually a little higher than the LS1? Just wondering.
Old 08-26-2006, 10:06 AM
memphiss13's Avatar
you have got to take me for a ride at the next drift event we're at erin. this is forrest btw. looks like alot of us are catching the v8 bug.
Old 08-26-2006, 10:10 AM
icantdrift's Avatar
absolutely man . i'll be hitting every event i can after the nopi demo.
Old 08-27-2006, 09:36 PM
mikespeed95's Avatar
correct, althought i cant remember exact.
all youpeople with hood clearance are makingme jelous. worst part is the blower is 3'' taller than the stock intake, and its 4.5'' higher than the hood
Old 08-27-2006, 09:54 PM
Ted J's Avatar
I'd take a blower sticking out of the hood and having to mod it over not having a blower with a stock type hood that can close without modification!
Old 08-27-2006, 10:45 PM
icantdrift's Avatar
i was prepared for it to not clear and to have to rework the hood a little, but i'm amazed that if i cut this rib out of the hood it'll work great. also test fitted the old strut tower brace and i have plenty of clearance on that too . my only real concern now is swaybar clearance on the pan... i may have to work some magic on that.
Old 08-28-2006, 11:59 AM
agreed!
Old 08-29-2006, 09:44 PM
icantdrift's Avatar
today's stuff....
made a throttle cable bracket to use the stock cable, as with most of my stuff it isn't pretty but it'll work.
bolted up the motor side of the mounts to start working on the bottom mounts
started just welding everything i could find to make lower mounts, in the end they aren't half bad.
how they look in and together
shifter alignment in the car
finally finished the trans mount, it will be cleaned up with the excess steel cut off and some extra bracing done but it works as-is
and the hotness shot
there's still a ton of work to do, but the hardest is done.
Old 08-29-2006, 11:26 PM
cool beans
Old 08-30-2006, 01:08 AM
memphiss13's Avatar
nice work. its interesting to see all the different methods of doing the mounts. each one works, just different approaches. your tranny mount is pretty much the way i imagined would work.
Old 08-30-2006, 04:46 AM
ranger2339's Avatar
Looks good man, i take it you are doing all cutome fabrications??
Ax
Old 08-30-2006, 10:22 AM
nice pics of the progress! awesome work man! the basic mount design is very similar to what hinson makes for the FC rx7 chassis, yours look nice too. I'm surprised youre gonna run solid motor mounts, yikes! even poly mounts in the stock setup are damn stiff but at least offer some flex for the motor.
you are now using the 240sx throttle cable? looks fine by the way.
shifter location is perfect! NICE!
the trans mount is a good idea, just slice-n-dice and rewelded with some metal to move the center section rearward?
that engine bay pic is soooooooooooooo wicked
Old 08-30-2006, 01:43 PM
icantdrift's Avatar
Ax
yup, this is a driveway swap .
Old 08-30-2006, 01:45 PM
icantdrift's Avatar
i don't want it to flex, this is a dedicated drift car that is occasionally driven on the street so it won't bother me. if it were to flex at all the pan would likely hit the x-member which i really don't want happening. when i pull the motor back out i'm going to clearance it a little more but solid is still better in my case.
thanks for the kind words, it's coming together nicely i think.
Old 08-30-2006, 07:17 PM
jjkamikaze's Avatar
the mounts im useing just have a very thin urethane sleeve type bushing similar to these.http://carshop.carshopinc.com/produc...2560e1b30648cc
and i was originaly looking at these as an easy base to make mounts off of. i bet these will work nice, someone should try them. you just need to weld the arm part to a plate welded to the sub-frame and your good to go.
Old 08-30-2006, 11:17 PM
DOHCsky's Avatar
i picked up a set of these mounts also, hope to give the motor a little bit of flex. great job on the tranny mount, i was kind of sweating after seeing the custom job ted did on his.
shawn
Old 08-30-2006, 11:18 PM
DOHCsky's Avatar
one more thing, how are you guys setting the drive shaft angle?
Quick Reply: one more S13/LS1 swap in the works
