Sound Deadener
!Dial-up Director
Sound Deadener
I am thinking of covering my entire interior with a sound deadener when my roll bar goes in. I want to reduce interior noise significantly. Weight is a concern also.
What is the best and lightest sound deadener out there? Dynamatt, Brown Bread, etc. Those who have it did it noticeable reduce interior noise?
How many sq/ft do I need to do the floor?
Thanks,
Justin
<small>[ March 09, 2003, 02:31 PM: Message edited by: Jsears8 ]</small>
Thanks,
Justin
Re: Sound Deadener
I just did this to my car and cut the noise in half, LITERALLY! Go to HomeDepot or Lowes and pick up 5 (I only used 4) of these:
Frost King
<img src="http://mikemercury.home.att.net/foilfoamsm.jpg" alt=" - " />
SKU on it is: 28929 at Lowes. Each roll only weighs ~3lbs. I did the entire flooring and back of the car. I didn't do the doors but let me tell you, it is a HUGE difference! I can barely hear my gear whine now and before I could barely hold a conversation. I only used 4 rolls but allow yourself 5 in case there are other areas you want to do.
It's $14.99/roll
Frost King
It's $14.99/roll
Re: Sound Deadener
CANNIBAL,
Does that have an adhesive on the back of it? I have Dynamat in my trunk and trunk lid for my subwoofers, which has adhesive on the back, but at $100 a pack it's not exactly cheap. And I would like to do the whole car.
<small>[ March 09, 2003, 03:16 PM: Message edited by: SS 414 ]</small>
!Dial-up Director
Re: Sound Deadener
Thanks Levi. Thats what I am wanting to get rid of, gear whine and exhaust noise, and as a side bonus make my stereo sound better. That stuff is twice as thick as Brown Bread but I wonder how it compares as an absorber/dampner. B quiet recommends there brown bread deadener + their Vcomp sound barrier. That would come out to ~1.4lbs per sq/ft.
SS 414, it says on the package that it is self adhesive. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Justin
Justin
Re: Sound Deadener
Yeah, it's self adhesive, goes on real nice <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . Jsears, I even stuffed a bit of R-13 fiberglass insulation behind the sail panel speaker (it's a HUGE hole back there with no dampening material). Now I have ZERO pingy noise **** from gravels hitting the rear tire well <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Re: Sound Deadener
i was thinking along those lines to(insulation)i work construction and i got a 4'x40' roll of it.my concern is moisture.once it gets wet the silver vapor barrier is not going to let it dry to easily.even if you put it vabor down any moisture underneath it would be trapped.i guess dynamatt wouldnt be to different. it may be self adhering but moisture or water(rainy days) will still find its way in. to who ever said they used this...did you remove the oem sounddeadner or just added the insulation with it? thanks
Re: Sound Deadener
oh buy the way....dont buy at lowes...when they build their stores they used out of state labor...meaning when the store in your area was built the workers came from somewhere else....lowes is notorious for this...thats just my 2 cents im not trying to highjack the thread. thanks
Re: Sound Deadener
I've got to hand it to the guy who posted the duct insulation. I have not used it myself, but I went to lowes looked over my shoulder and cut off a little piece. It is exactly the same as cascade mat. cascade is another dynamat. I get cost at the dfw distributor for cascade so I have always used it. The duct insulation is just as goood. I would say run with it. Even at dealer cost the duct stuff is still a fifth of the cost.
Re: Sound Deadener
Wow! What a kickass alternative. I'll be doing that this weekend. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> for the great idea!
Re: Sound Deadener
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by richieg:
<strong> I've got to hand it to the guy who posted the duct insulation. I have not used it myself, but I went to lowes looked over my shoulder and cut off a little piece. It is exactly the same as cascade mat. cascade is another dynamat. I get cost at the dfw distributor for cascade so I have always used it. The duct insulation is just as goood. I would say run with it. Even at dealer cost the duct stuff is still a fifth of the cost. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You're welcome. Works AWESOME!
Location: Richmond, VA Where fast cars, well......are hard to come by.
Re: Sound Deadener
Man that's a great idea! I smell a weekend project coming up... <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Re: Sound Deadener
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by last of the Z28's:
<strong> i was thinking along those lines to(insulation)i work construction and i got a 4'x40' roll of it.my concern is moisture.once it gets wet the silver vapor barrier is not going to let it dry to easily.even if you put it vabor down any moisture underneath it would be trapped.i guess dynamatt wouldnt be to different. it may be self adhering but moisture or water(rainy days) will still find its way in. to who ever said they used this...did you remove the oem sounddeadner or just added the insulation with it? thanks </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So is the moisture thing something to worry about?
!Dial-up Director
Re: Sound Deadener
Well, after telling my girlfreind there might be a cheaper alternative to cascade, off to the garage with her toyota rav4. I lined the floor and front door panels with the duct stuff. I can't really explain it, and your car might react different. but in her rav4 it literally cut out all of the road noise completely, the only thing left was wind noise. Coming from a car audio shop, I never got that kind of result from dynamt or cascade. go figure.
Re: Sound Deadener
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jsears8:
<strong> http://mikemercury.home.att.net/sound.htm </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Looks good, how long did it take you to do?
Re: Sound Deadener
Sounds good CANNIBAL. Now I guess I just gotta find time to take the interior out. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
